Please provide pictures of the boards, cables and the make/source/sizes of SD cards.
Did you use shrouded headers? If so, you can’t plug the cables in the wrong way, unless they’re incorrectly assembled.
21 hours ago, niles said:
Thanks for the ongoing help. Do you know how to format FAT8 on a windows 10 machine? I have been googling but can’t find any program. I did find an older post by TK that says formatting via MIOS Studio is the best method by doing sdcard_format, but it fails with this:
Try to format using some sort of FAT setting. Is the format successful in Windows?
Quote
If I had the cable backwards on one end by accident at some point would that have done some damage somewhere?
Not seen before, but I guess so? You could’ve damaged the SD card, the MCU pins or both. Again, can you still format the SD cards or are they unresponsive in Windows?
Quote
If I lay the cable down flat, with the connector holes pointing up, the notches are on the same side of each connector. I assume that’s the right orientation.
That’s right, but above you were saying that maybe the cables were backwards? Were they incorrectly assembled before? Shrouded headers or not? See above comments
Quote
Edit - Also just in case it helps, only the green LED has been lighting up.
J16E carries the LED signals too. If there was a “backwards cable”, then something funny could’ve happend there. But you don’t get many LED signals with _NG. More are active with the SEQ app.
Here’s the schematic. The SD card pinout follows the datasheet that you can get from Mouser.
Check for continuity of pins back to the Waveshare 407v board (with the power off). Check that adjacent pins are not shorted. Make another cable or use the one from an OLED at least temporarily (don’t use the OLED cable!) You can measure voltage at the SD card. You won’t see much with a multimeter on the other pins, but you can use a scope or logic probe if you have one.
Also, it is possible to overheat these SD sockets. What temperature settings did you use? Were you heating the pins for a long time?
