MIDI_CORE_LPC17 PCB?
I currently want to build the MIDIO 128 v3 (including the lpc17) so i managed to buy a lpxpresso1769. The components are easy to get, but i didnt find any way to get the PCB. Is there any way to buy a PCB online thats already made?
oh, and does anyone know what the dimensions of the PCB are? i just found the datasheet including the Value 100 x 120, but im not sure about the unity.
Greetings,
Kilian
i still have the nude CORe_LPC17 board layin around here available for sell. PM me for more details.
Bests,Jerome
As far as I can see the LPC 17 Core PCB is not available to buy anymore from Smash TV’s and Mikes Midibox shops but you can still buy the newer CORE STM32F4 PCB and kit from SmashTV.
http://midiboxshop.bigcartel.com/
Keep in mind you would need to purchase the STM32F407G-DISC1 evaluation board externally.
That would be the easiest way to proceed.
You should always make sure all components are available to buy  (such as the PCB) before ordering anything, it can save cost in the long run. :slight_smile:
Take care because between EA board rĂ©vision there is difference in the position of the central pins which make the core not compatible with it, the good rĂ©vision is B if I remember well, C doesn’t match.
Ask for the révision before order it.
Thank you for your advice.
I just checked it and its rev B so no problem.
Greetings,
Kilian
On 9/14/2016 at 9:30 PM, Antichambre said:
the good révision is B if I remember well, C doesn’t match.
Interesting, I didn’t know that. I have one more LPC core that I plan to stuff. Does anyone happen to know if LPC1769 revision D, currently available on the embeddedartists site, is compatible with LPC core? They claim that:
“the expansion pins (2x27 positions) are mechanically compatible with the original design”
but I’d like to check if anyone here has experience with it before I order.
Maybe the core was revised too, since I bought it. But, mine is only compatible with rev B.
I’m pretty sure, Lextronic has a stock of revB, but ask them before.
Hi There,
thanks for your kind answers. I now have all Components at home.
And thanks again Psykhaze for the PCB  :wink:
Greetings,
Kilian
Lextronic now have this board does it the original or need some hack too?
i have a lpc19_v1 board!
everything work as was writes here:
http://www.ucapps.de/mbhp_core_lpc17.html
https://www.lextronic.fr/lpcxpresso/14902-module-lpc1769-lpcxpresso-board.html
I don’t order board from them since a moment…
If you want to be sure just ask them the revision of the board before order, rev A or B fits the core without modification.
Best
Bruno
And everything works as the how to on ucapps site?
And if it’s D only need to replace the leg with wire?
Or this model I need a new Bootloader method?
They have only Rev C! Buy it or not, I only need the end legs to prepare to your place?
Other size is same?
Or buy this D because it’s better than C?
Please somebody tell me C or D???
C doesn’t fit.
D: no experience with it.
37 minutes ago, FantomXR said:
C doesn’t fit.
Totally no fit or just the end part?
Buy one, try it and report back.
