Just now, latigid on said:
Buy one, try it and report back.
Yes I am a millionaire… If not work go to trash and buy other… Fantastic
If you don’t like to do “trial and error”-work DIY might not be the best thing for you to do.
I expecting your zen years experience…
Hello,
A = B = fits exactly the ucapps core board footprint.
C = D = don’t fit exactly the ucapps core board footprint.
=> for C and D we need to use wire or to bend a part of the header.
Sorry if I wasn’t clear before.
For all cases bootloader is the same method, except that you will maybe need to advise Memory address at burn, depending on version of your LPCXpresso ide, see
Best
Bruno
You can use the D. If you do not solder it first you do not have to bend or use wire. there is enough flex in the header and sockets to get it to line up and once it is aligned you solder. If you solder first you will need to bend the pin legs or replace them with wire. It is a bit tricky to do but it does work.
I can’t find rev d on market just one rev c
I aborted my order! Wich to continue to lpc 19 rev d or new STM32?
Please stop flooding the forums - you can find everything documented well, as all the others told you already. And yes, it always makes sense to use the current core and not an old one, so STM32F4 is the way to go…
