Re: PowerSupply
Not really relevant as I made the first test with computer loudspeakers.
I heard no hum…only the classical SID noise.
I will advice you as I will test with a serious audio setup.
Greets
Antonio
Re: PowerSupply
Greets
Antonio
Re: PowerSupply
Cool, thanks!
Gotta check my filtering capacitators, i really suspect them, by now…
Greets,
Peter
Re: PowerSupply
I used two low RS 2200uF 35 V Nichicon capacitors ( total of 4400 uF )
Re: PowerSupply
Thanks, I´ve only got one just ahead of the 78S05 - where have you put the second? In “series” with the first? Is more capacity necessary for larger transformers (3+A on the 9V ~ transformer output?)
How can the irregular 5V supply affect the SID output anyways?
I thought they were (only) 9V powered?
Thanks for your time, sorry for the many questions and have a great weekend!
Peter
Re: PowerSupply
SID powers
Vdd 9 / 12 V
Vcc 5 V
anyway the ground is common with core so probably 5 V can influence 9V
The caps are in parallel 2 x 2200uF ( 4400 uF )
usually I use “larger” capacitors for
" large " current power supply so I think that only 2200 uF it is not enough for 3Amps… when you start to need more amperes a little capacitor may cause ripple.
try enhancing capacitors value.
( to reduce RS use two caps instead of one bigger for example : two 2200uF instead of one 4700uF)
Regards
Antonio
Re: PowerSupply
Wow, thanks for the help Antonio! Will try that soon!
Have a great weekend and lots of joy with your MB6582 ![]()
Best regards,
Peter
Re: PowerSupply
You are welcome ![]()
I hope that the hum disappeares
Have a nice weekend you to
Antonio
Re: MB6582 Supply
Where can I find the wiring diagram?
Was the power supply already tested at a MB-6582?
/topic/16065-strange-voltage-issue-with-mb-6582/?do=embed" frameborder=“0” data-embedcontent=“”>
Any suggestion to this?
best regards
Re: MB6582 Supply
http://www.retro-donald.de/pages/hardware/basteleien/powernetzteil.php
/topic/14564-building-the-mb-6582-control-surface-photo-tutorial/page__st__40?do=embed" frameborder=“0” data-embedcontent=“”>
Here some info ![]()
Re: MB6582
Very nice ![]()
Re: MB6582
Cool ambience, as usual ![]()
Re: MB6582
Thanks Peter ![]()
I am seriously starting to think to a 6581 and red led version.
Re: MB6582
That would make for a great pair ![]()
Green and mean 8580
Red and dirty 6581
Also, 16 SIDs in parallel = geek heaven ![]()
Re: Fully stuffed
gratz :frantics:
Re: Fully stuffed
Nice.:sorcerer: Mine still needs another 4 SIDs, about 6 months after I built it. May I ask where you got those heatsinks from?
Re: Fully stuffed
Also my hunt lasted several months.
At th beginning i had only three 8580.
The heatsink are from RS ( i dont remember the code but you can search 28 dip heatsink )and the double adesive tape is “AKASA Thermal Tape”
regards
Re: Fully stuffed
Thanks Antix
Re: Fully stuffed
Great heatsinks! ![]()
Re: Fully stuffed
Thanks Peter,
Them have a nice shape and keep little warm our loved SIDs
( I noticed how actually the 8580 can become hot without heatsink :excl: )
Regards
Antonio
Re: Linear Supply
Nice! well done with PCB! ![]()
