Re: MBFM
Please tell me how you did the paint work and got the text so nice … did you silk screen?
Re: MBFM
Re: MBFM Desktop
Thank Grizz ![]()
Re: MBFM
Hi Nebula,
yes silk screen for the text and acrylic paint for the other graphics.
but I have to learn to be more accurate, the characters are OK but the border of the black frame is not very clear.
Regards
Re: MBFM
Looks great, man!
Re: MBFM
Thanks guys,
Still missing the plexiglass window on the lcd ( you can see the holes for the screw )
so…it is not really completed yet.
But I can play it the same
Regards
Re: MBFM
Nice! I like it.
Re: MBFM
Fantastic! Well done!
Re: MBFM
Thanks Guys
I am grateful for your appreciation
Greets
Antix
Re: MB6582 Supply
That looks good ![]()
If I only could remember where I´ve seen a PSU like this before ![]()
Re: MB6582 Supply
also nice to see the crowbar circuit ![]()
Could you do an A-B listening test with your old C64 PSU, if you have one?
I seem to have slightly more noise with this PSU (like a 50Hz hum, but don´t know where it comes from- the components are all top-notch and the capacitators should work their ripple-softening magic…)
Greets, Peter
Re: MB6582 Supply
Yes…
if you make me think about …seems that
I see something like here in the forum
:whistle:
Re: MB6582 Supply
Peter,
I dont understand ; do you have noise with C64 PSU or with this new PSU?
Yes I have an old C64 PSU for comparison but I will be able to do the test when I will finish the MB6582.
Antonio
Re: MB6582 Supply
Hi Antonio,
I feel to have a little bit more noise with the new PSU… but not really very well audible, i´d be interested if you hear it, too - but no hurries… have fun building the rest of the MB6582 ![]()
Greets,
Peter
Re: MB6582 Supply
OK now is clear ![]()
It is strange as you used modern el-parts.
may the crowbar section insert some noise ?
This is the first time I use it in my linear supply ( usually I trust in 78xx ).
Greets
Antonio
Re: MB6582 Supply
Hi Antonio,
I am not good enough in electronics to guess what is exactly wrong… but I somewhere read, that ground-hum can be because of the ground connection between different audio gear, that have different PSUs.. gotta read more regarding this… and test, if the hum also occurs, if I only plug head-phones into the MB6582…
Other possibilities would be the crowbar, as you mentioned (could deactivate that subcircuit for a test)… or wrong filtering capacitators…
but I don´t have a oscilloscope to have a peek, yet ![]()
But it is not really problematic, just barely audible, and am interested, if you hear it, too ![]()
Greets and have a good time!
Peter
Re: MB6582 Supply
3 Ampère ? and you use Vregs in TO-220 package !!
please please which Vreg are you using? i just know the 78Sxx / 79Sxx type that can deliver a max of 2A.
but i need moar :rolleyes:
Re: PowerSupply
Very nice, including the two LEDs ![]()
Re: MB6582 Supply
MC78C05T FTW!
3 Amp TO220 5V Voltage Regulator
http://www.datasheetcatalog.org/datasheets/166/438769_DS.pdf
Re: PowerSupply
Thanks Peter
Green for 5
orange for 9
Re: PowerSupply
Hi Antonio,
Cool! - we have an interesting build difference - I have green (5v after vreg) and another green (5v after protection circuit) ![]()
Do you already have comments on audio quality/audible hum?
Greets!
Peter
