OK here I go again:
TEST PC1 and TEST PC2:
As I already mentioned I am using MIOS Studio on a linux laptop:
pc-midi-out -> pc-midi-in
first block of the 6581-sid-hex-file:
midi-out-monitor:
timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 0C 00 00 20 15 7B 63 3F 04 3B 5E 1B 78 28 1D 71 5F 42 51 6F 0D 7C 18 6E 78 6F 61 74 77 46 7E 04 4F 3C 39 70 27 3B 63 4F 01 5B 5E 1C 78 0E 7D 71 67 41 1F 6F 0E 3C 00 1E 78 73 61 7F 77 46 7E 0F 67 3C 37 70 7F 3B 63 3F 04 03 5E 1A 78 3A 3D 71 57 43 6F 6F 0D 3C 1F 3E 78 6B 60 0E 77 47 1E 00 6F 3C 39 70 54 3B 63 2F 05 4F 5E 1A 78 3F 1D 71 57 40 24 00 00 00 02 20 00 00 00 12 00 00 00 01 10 00 00 00 09 00 00 00 00 48 00 00 00 04 40 00 00 00 24 00 00 00 1F 7F 7A 09 08 00 00 15 48 40 08 01 54 44 01 00 1B 24 20 1C 01 56 22 01 40 0D 12 10 0A 00 67 11 00 40 06 29 08 03 00 31 48 4F 40 03 04 44 7C 00 17 64 27 60 01 3A 22 3E 00 0B 32 13 70 00 78 11 01 00 07 51 08 09 00 3E 08 40 50 03 78 44 05 40 13 24 28 30 00 50 24 03 20 05 42 20 1C 00 0F 11 43 20 06 51 0C 1B 00 23 08 61 60 02 60 46 0E 40 03 44 39 08 00 3A 23 48 60 05 62 1C 64 00 5C 11 66 30 06 29 0E 34 00 38 48 73 28 01 58 48 1B 00 0E 04 40 1F F7
midi-in-monitor:
00000000074542 ms | Sysex message: F0 00 00 7E 40 00 02 0C 00 00 20 15 7B 63 3F 04 3B 5E 1B 78 28 1D 71 5F 42 51 6F 0D 7C 18 6E 78 6F 61 74 77 46 7E 04 4F 3C 39 70 27 3B 63 4F 01 5B 5E 1C 78 0E 7D 71 67 41 1F 6F 0E 3C 00 1E 78 73 61 7F 77 46 7E 0F 67 3C 37 70 7F 3B 63 3F 04 03 5E 1A 78 3A 3D 71 57 43 6F 6F 0D 3C 1F 3E 78 6B 60 0E 77 47 1E 00 6F 3C 39 70 54 3B 63 2F 05 4F 5E 1A 78 3F 1D 71 57 40 24 00 00 00 02 20 00 00 00 12 00 00 00 01 10 00 00 00 09 00 00 00 00 48 00 00 00 04 40 00 00 00 24 00 00 00 1F 7F 7A 09 08 00 00 15 48 40 08 01 54 44 01 00 1B 24 20 1C 01 56 22 01 40 0D 12 10 0A 00 67 11 00 40 06 29 08 03 00 31 48 4F 40 03 04 44 7C 00 17 64 27 60 01 3A 22 3E 00 0B 32 13 70 00 78 11 01 00 07 51 08 09 00 3E 08 40 50 03 78 44 05 40 13 24 28 30 00 50 24 03 20 05 42 20 1C 00 0F 11 43 20 06 51 0C 1B 00 23 08 61 60 02 60 46 0E 40 03 44 39 08 00 3A 23 48 60 05 62 1C 64 00 5C 11 66 30 06 29 0E 34 00 38 48 73 28 01 58 48 1B 00 0E 04 40 1F F7
TEST PROG1: The display already shows the copyright-text and then “Ready.” So I guess this is redundant. I had the PIC preprogrammed with MIOS from doc.
TEST CORE1: yes the crystal is oscillating.
TEST CORE3: I couldn’t find any bad solderings.
TEST CORE4: Vdd is between 4.98 and 5.01 on all check-points.
TEST CORE5: ground is alright, too.
TEST CORE6: midi plugs should be connected properly (I think the following tests are also suggesting this)
TEST CORE7: polarity of the diode and the diode itself is working.
TEST CORE8: resistor values are ok.
TEST CORE9: of course I have it cross-linked.
TEST CORE10: I don’t notice a lot of upload requests.
TEST CORE11: The cap etc should be fine. How could I test this in more detail? The alive-message I reveive when powering up is correct.
TEST OUT1 and TEST OUT2: I get an “alive-message” when powering up the Core. So this should be redundant.
TEST IN1: all the resistors seem to be fine.
TEST IN2: the midi plugs should be ok since the following tests work.
TEST IN3: the led is lit and flickers when sending a series of sysex-messages.
TEST IN4 and TEST IN5: I haven’t tried it but it has to work since the previous test works, right?
TEST IN6: the optocpupler-test works, too.
TEST IN7: I haven’t tried it, assuming that the previous test makes sure the optocoupler works. Tell me plese if I am wrong.
TEST INOUT1: I was sending the beginning of the 8581-hex-file and the midi-in is empty so no log availible.
I hope I got it all together now and thanks for the fast reply stryd_one
