Win XP x64: Do I need new midi driver for ltc?
Hi there!
I am going to switch to x64 in a few day. Does anyone know if I need other drivers than those for the audio-interface for 64bit? I am using my midiboxLC with the serial cable. I doubt there will be new drivers for that anywhere.
Will it work or is there something else I should consider?
cheers,
rambinator
You could always try vmware and make a test install. Try to see if your things work before migrating to x64. Usually when its on a serial port you do not have to worry about things. But i can’t tell for sure.
regards,
Jef
Seems like the yamaha cbx driver makes some problems. I can install it under 64 but it doesn’t show up in sonar 64
You might have trouble, from what I remember reading x64 edition needs new 64-bit drivers for just about everything.
Good luck, I hope you find some!
Therezin is right. For x64 you’ll need new drivers for every device. No reuse of 32bit drivers is possible.  :frowning:
