Will these Illuminated Encoders work?
Hello,
i`m new to DIY midi controlers, but am interested in building a box with 16 encoders and two buttons for paging the encoders to the next or previous 16 CC messages.
Also i would like to have two additional buttons for other purposes.
I want to use the CORE_STM32F4 Module
http://www.ucapps.de/mbhp_core_stm32f4.html
and two of these DIN X4_ V2 modules
http://www.ucapps.de/mbhp_din.html
What i now am wondering about is wether these encoders would be suitable for that build and if anyone has experience further readings or anything else related to these encoders.
Any help or information would be great.
Did anyone of you use them in a project?
http://www.cliffuk.co.uk/products/encoders/index.htm
many thanks!
Mark
Hi Mark,
the encoder spec (http://www.cliffuk.co.uk/products/encoders/EncoderSpec.pdf) looks fine, it will work :slight_smile:
Note that MIDIbox NG allows to connect up to 16 buttons to J10A/B, see also this configuration example: http://svnmios.midibox.org/filedetails.php?repname=svn.mios32&path=%2Ftrunk%2Fapps%2Fcontrollers%2Fmidibox_ng_v1%2Fcfg%2Ftests%2Fdiocfg_1.ngc
This means that you only need a single MBHP_DINX4 module for 16 encoders, the two buttons can be connected to J10A.D0 and D1, and with “DIO port=J10A emu_din_sr=5” they will be available as BUTTON:33 and BUTTON:34
Hi Thorsten,
super, thx for your response.
I still wonder because of LEDs. Since i would like to use the bi-colored once. Green/Blue, i would need two additional inputs for each encoder right? Plus the switch also got its own circuit i guess. So 3 additional inputs. This wont be possible with just one DIN X4 module right?
Also i found this ones here: http://at.rs-online.com/web/c/?searchTerm=tyco+encoder
They are the same i think, just another vendor but located in Austria, wich is good for me, since im located in germany.
Here are the specs:
http://docs-europe.electrocomponents.com/webdocs/0ccf/0900766b80ccf883.pdf
Would these also work?
What i also wonder is if i should use the ones with a flatted or knurled shaft. Any ideas?  I don`t know wich one is for what.
And if i would need the vertical ones or horizontal ones.
cheers
Hi suloo I once made a pcb for RGB colored encoders. You can find the compleete dokumentation in the wikipages: http://www.midibox.org/dokuwiki/doku.php?id=fadercore_-_vlr-8enc Feel free to download the Eagle files an expand it to 16… Best regards Novski
Can’t give you a better reference project than Novski :slight_smile:
Wow, nice one! That looks awesome. I also thought about a motorfader controler for the next project. hm :slight_smile:
Will check that one out for sure. Thx!
