Short answer: I have the same number of sammichSID base PCB and control surface PCBs. Selling one separately to the other means I’m left with a potentially unsellable board. Not worth my trouble.
Long answer: Considering the MB-6582 base PCB already has the DIN/DOUT for a full CS, and the sammichSID CS also has DIN/DOUT for a minimal CS, combining the two is not only very redundant, it’s a bit of a wasted opportunity. It is so easy to stick a few switches on a prototyping board and connect them to the MB-6582 base PCB, and this not only is cheaper, you can make it exactly the way you want, instead of being forced to use the incredibly minimal sammichSID CS. I mean, if you want the buttons in the exact same places then you could do that now with prototyping board, you won’t need a sammichSID PCB… but if you add just a little bit more effort, you could use a 2x40 LCD or a 4x20 LCD and make something so much better.
Wilba,
I don’t necessarily need to use the sammichSID CS board. I was indeed thinking of using a 2x40 LCD, as I already have one. And some encoders.
I guess I’m more interested in the details of the DIN/DOUT configuration for the sammichSID…how you implemented the used definable buttons, for example.
Another option is to buy the MB-6582 CS board and only partially populate it. Sandwich the 2 boards like the sammichSID, then just run control wires for those switches and encoders that I want to use. I can see it being worth the $20 for improved reliability.
I would probably also want the feedback pots on the front panel. I would put everything in an old C-64 case and integrate the power supply.
A more general question of interest is : When using the full control surface, which controls get used the most? What is the optimum control surface complexity that lies between the sammichSID and the full blown CS-6582?
I’m also interested in being able to use the MB-6582 as more of a standalone device…kind of a Midibox SID jam box.
Don’t get me wrong – I’m very impressed by what you have done, but personally want something with a simpler interface.
Thanks,
Tom
