But I want to know exactly how an arpeggiator works in a synth. I mean, how do you/would you implement one? By rapidly playing the note over and over as the person holds down a key or what?
I just wonder if anyone has any further explanation or discussion, as I might want to include an arpeggiator on my synth.
Basically what an arpeggiator will do is arpeggiate a chord you play. So let’s say your arpeggitor is set to “Up” mode and is set to spawn 2 octaves, then if you hit the C chord (C E G), it will play those notes in a sequence at a certain predefined speed. So in 2 octaves it would play
Ok, that makes perfect sense. Does anyone have any links to any samples of arpeggio?
I’ll check around on the site and see if I can find any. This sounds like something cool I’d like to implement. Hopefully I can get it right without having to do too much guesswork.
Thanks,
-Flecko
EDIT: Found some examples, this is awesome. I…must…implement!
