hi,
I was wander if someone could help me with this project.
I would like to build something like Velocity Converter from Midi Solutions…
http://www.midisolutions.com/prodvel.htm
Does anyone know some DIY project for that converter?
Thanks
Andrea
hi,
Thanks
Andrea
You could easily code something like this with the C interface if you have some programming skills?
Unfortunately no…
Andrea
To my knowledge, a mbhp version of this do not exist yet, but if you are able to describe with enough precision what it’s supposed to do, then i guess someone (maybe me) can help you to do it.
It should not be much complicated anyway.
bill you are a BIG man!
Thank you Bill, you are wery kind.
The converter that I am talking about is similar to Velocity Converter from Midi Solutions but a more simple one could be usefull.
The converter is able to transorm a velocity value of an incoming midi message into another value. In this way you are able to change the velocity curve for your MIDI keyboard.
It means that it let’s you remap the function which maps the strength you hit the key to the volume the note plays.
The problem is that my keyboard doesn’t have a function to customize the velocity curve. When I use it with a external sound module the dynamic response is completely different. For example, you have to hit wery strongly (I mean very!!) if you want to send a velocity level of 127 to the expander.
There is a freeware software that allow you to change velocity curve : Midi velocity curve changer (Trombettworks Software)
http://www.trombettworks.com/velocity.php
but I am looking for something that works without pc.
I am sure that this can accomplished with MIDIBOX, but unfortunately I am just a piano player and I don’t have any programming skill.
This can be an additional use of mIDIBOX that can solve a lot of problem in a simple way.
Thanks
Andrea
What about the curves ?
Should they be linear ? (initial value * boost factor)
Should they be transposed ? (initial value + gain)
or maybe precalculateds ? (then give the values or formulas)
Make the curves editable from a control surface will make this project lot more complicated, so i guess it’s not what you want, right ?
wtf ? you mean, i’m “fat” ? how do you know that ? ^^
;D
Thanks
Andrea
Check this : http://www.midibox.org/dokuwiki/doku.php?id=velocity_converter
you are right bill, I don’t need a unit with curves editable from a control surface but I am interested to have just a fixed and precalculated conversion between velocity in input and velocity in output.
I mean, using Midi Velocity Changer, I found the suitable conversion curve that I need to adapt my keyboard to the expander.This program is able to display the change between in and out and so I have a table of conversion of vel. in to vel. out
Here I reported a piece of that table for example:
In OUt
000 –> 000
001 –> 002
002 –> 003
004 –> 007
005 008
103 119
104 119
125 127
126 127
127 127
I need just a unit that apply this fixed conversion between midi velocity in Input and midi velocity in output.
Eventually it could be interesting the possibility of choosing diffrent conversion table (precalculated with Velocity Changer) from the control surface…but it is not necessary. I will be very happy to have just a single conversion table.
with this unit I will be able to play live my keybord and my expander without a computer with Velocity changer.
Thank you bill!!!
By
Ok, it’s your turn to work a bit :
fill (replace the “0” with your values) that array thanks to your values.
const char curve1[127] = {
//out // in
0, // 0
0, // 1
0, // 2
0, // 3
0, // 4
0, // 5
0, // 6
0, // 7
0, // 8
0, // 9
0, // 10
0, // 11
0, // 12
0, // 13
0, // 14
0, // 15
0, // 16
0, // 17
0, // 18
0, // 19
0, // 20
0, // 21
0, // 22
0, // 23
0, // 24
0, // 25
0, // 26
0, // 27
0, // 28
0, // 29
0, // 30
0, // 31
0, // 32
0, // 33
0, // 34
0, // 35
0, // 36
0, // 37
0, // 38
0, // 39
0, // 40
0, // 41
0, // 42
0, // 43
0, // 44
0, // 45
0, // 46
0, // 47
0, // 48
0, // 49
0, // 50
0, // 51
0, // 52
0, // 53
0, // 54
0, // 55
0, // 56
0, // 57
0, // 58
0, // 59
0, // 60
0, // 61
0, // 62
0, // 63
0, // 64
0, // 65
0, // 66
0, // 67
0, // 68
0, // 69
0, // 70
0, // 71
0, // 72
0, // 73
0, // 74
0, // 75
0, // 76
0, // 77
0, // 78
0, // 79
0, // 80
0, // 81
0, // 82
0, // 83
0, // 84
0, // 85
0, // 86
0, // 87
0, // 88
0, // 89
0, // 90
0, // 91
0, // 92
0, // 93
0, // 94
0, // 95
0, // 96
0, // 97
0, // 98
0, // 99
0, // 100
0, // 101
0, // 102
0, // 103
0, // 104
0, // 105
0, // 106
0, // 107
0, // 108
0, // 109
0, // 110
0, // 111
0, // 112
0, // 113
0, // 114
0, // 115
0, // 116
0, // 117
0, // 118
0, // 119
0, // 120
0, // 121
0, // 122
0, // 123
0, // 124
0, // 125
0, // 126
0, // 127
If you are motivated, “draw” many curves, and give them different names like curve1 curve2 curve3.
Ok bill, you are great!!
The most important is curve 1 (that is curve that I usually use).
I can draw more curves, but I need time to set up my feeling with the dynamics. I think that you can edit random curve 2, curve 3..(just putting random values or leave linear relation:000—000, 001—001… 027—027 etc…) and you can show me how I can modify by my self the conversion table of these curve.( I think 4 or 5 curve will be more than enought). In this way I can edit and correct the values any time I need without disturb you…are you agree??
Do you think that it is possible to see on LCD which curve I am using??and if the unit is working of no?
Thank you again for your time!!!
This is my curve 1.
//out // in
0, // 0
2, // 1
3, // 2
5, // 3
7, // 4
8, // 5
10, // 6
12, // 7
14, // 8
15, // 9
17, // 10
19, // 11
20, // 12
22, // 13
24, // 14
25, // 15
27, // 16
29, // 17
30, // 18
32, // 19
34, // 20
36, // 21
37, // 22
39, // 23
41, // 24
42, // 25
44, // 26
45, // 27
46, // 28
48, // 29
49, // 30
50, // 31
51, // 32
52, // 33
53, // 34
55, // 35
56, // 36
57, // 37
58, // 38
59, // 39
61, // 40
63, // 42
64, // 43
65, // 44
67, // 45
68, // 46
70, // 48
72, // 49
73, // 50
74, // 51
75, // 52
77, // 53
78, // 54
79, // 55
80, // 56
81, // 57
82, // 58
83, // 59
84, // 60
85, // 61
86, // 62
86, // 63
87, // 64
88, // 65
89, // 66
90, // 67
91, // 68
92, // 69
93, // 70
94, // 71
95, // 72
96, // 73
96, // 74
97, // 75
98, // 76
99, // 77
100, // 78
101, // 79
101, // 80
102, // 81
103, // 82
104, // 83
105, // 84
106, // 85
106, // 86
107, // 87
108, // 88
109, // 89
110, // 90
110, // 91
111, // 92
112, // 93
113, // 94
114, // 95
114, // 96
115, // 97
116, // 98
117, // 99
117, // 100
118, // 101
118, // 102
119, // 103
120, // 105
121, // 106
121, // 107
122, // 108
122, // 109
123, // 110
123, // 111
124, // 112
124, // 113
124, // 114
125, // 115
125, // 116
125, // 117
125, // 118
125, // 119
126 // 120
126, // 121
126, // 122
126, // 123
126, // 124
127, // 125
127, // 126
127, // 127
The Version 0.2 :
They are 16 Preset curves. Moving the pot From min-max select the desired velocity curve.
Curves must be tuned to your needs. (No editor yet)
Curves are separated into distinct files for user comfort : curve1.c, curve2.c, …, curve16.c
http://jambonbill.free.fr/Velocity_converter/velocity_converter_v0.2.zip
Thank yu Bill,
I am going to test it and I will let you know!!
I am sure that it will be great.
Andrea
http://www.stoffelshome.de/mvc.html
hope this will help you.
