V2 Buttons not responding
My buttons are not responding. Checked for solder bridges, jumpers correct, power in all locations and I have ground continuity. The Saamich SID (2matched ICs, correct caps in right holes, 1-3, 4-6) is recognized by MIOS. MIOS 1.9g SID 2.046 sent and received and reboot correctly LEDS fblink corrcetly and it goes to teh initial sound scree, But no buttons respond. Enocder turns but does not change the screen. I have sent presets via sysex and that went okay.
Do I have to upload a third hex file for the type of chips as well? I have it in the download package but there are no instructions in the build guide or the readme about those chip specific hex files.
What do I need to check?
In the docuwiki the link to an unnamed app for checking buttons is dead. Without the app name I cannot search for the app. stumped.
I went through carefully and resoldered pin connectors and saw some microscopic solder and lots of flux from years ago when I made this and shipped it off and cleaned with alcohol, a dental pick and a toothbrush. Pulled the 74h chips, reseated them and everything is now scanning. reinstalled the setup hex file and the vintage patches. Went back to 6581 chips and their caps. Some sound now but the sounds do not respond to pitch from the MIOS keyboard, which is on the same channel used for successfully sending the hex files. Odd.
So I took it apart for the nth time and resoldered, cleaned flux between pins and resoldered everything around my midi chip and all is well. I am so unimpressed with my years old soldering job on this. No wonder I had problems! Now onto learning ctrl. I still dont understand if the row of bank chips is just one bank (A) or a bank per chip that I can swap between. It seems like each time I load presets it overwrites the last group or am I missing something. The documentation assumes a lot of user knowledge that isnt there in my case.
it’s a bank per chip, and the last chip is for ensemble preset, it’s explained here in the manual: MIDIbox SID V2 User Manual --- First Steps
By the way, if by chance you use reaper, i made a plugin that controls all the parameters (even the wavetable) with a graphic interface. I posted it here New interface plugin for Reaper but i’ve got no feedback so far.
Thank you. I didn’t realize the banks are letters but in MIOS Librarian its numbers, I kept writing over the same bank with the four presets, what a moron. I figured my soldering was wrong. However I just finished a second kit successfully one with 6581s and one with 8580 s chips and was doing the same mistake when I noticed the bank box. Duh! Both SammichSIDS are running now. Looking for presets to fill the blanks in Bank 2 and 3. Is there a quick way to switch banks? The manual is a bit vague on newbie things.
from what i can read on the manual, from the main screen you press the first select button on the left once to enter the ensemble menu, a second time to enter the sid menu, and then you select the bank pressing the second select button and, i guess, moving the data entry knob or pressing up & down. I don’t know for sure since my build is without any interface, so i control it only via software
