I’m using MBHP in a project where it is a little away from the computer I’m coding on.
It would be really cool to be able to use MIOS Studio with the core wirelessly!
Using MIDI i/O
I will be trying a bluetooth serial adaptor at each end (which I have on hand). This involves Max232 level shifters at the host PC Midi Port. I’ll use a GM5 module TTL midi connection to the max232.
Another max232 at the core end to attach the bluetooth dongle. I’m not sure whether the adaptor will support the midi baudrate…will find out.
Pros of this approach is the excellent range of Bluetooth.
Using USB I/O
This would/should have the benefit of being able to access the USB port on the core as COM and MIDI and MassStorage.
Using a product such as this: Dlink
Or this:CablesUnlimited
Question is would such wireless links work with all classes of USB device? (The CableUnlimited product does not support isosynchronous transfers, so perhaps not MIDI.)
The Dlink product being a hub looks more promising (although it states that it does not support USB webcams, I wonder if this is due to throughput?)
Anyhow does anyone have experience using a product such as this with MIOS32 cores?
