Hi Robin,
If called does the SM-ButtonHandler function perform once only? Or can it perform several times ?
USER_Tick will be called by MIOS in an endless loop, so yes: it will be called several times until you power-off the core.
Beside of USER_Tick, several other handlers will be called consecutively, e.g. the DIN and AIN input checking routine, the MIDI parser, the MIOS_DISPLAY_Tick routine, etc… and once the execution of these handlers has been finished, the sequence re-starts at USER_Tick
This method is also called cooperative multitasking
So long the other handlers are idle (no DIN/AIN change, no incoming MIDI events, no LCD output, etc) USER_Tick will be called with a period of 20 uS, which is pretty fast!
What happens if the function takes too much time?
In this case, the other tasks will be blocked. The max. acceptable delay depends on your application.
There is only one strict requirement: it should never take more than ca. 20 mS, because if the MIDI parser is not called within this time span, the MIDI IN buffer could overrun
Note also: than longer USER_Tick takes, than longer the slack time of the other tasks
If my own applications, I’m trying to reduce the max. execution time of USER_Tick to less than 1 mS
If it takes longer, I program the functions which are handled by USER_Tick in a way that they will be processed step by step with each call of USER_Tick - example: when I’m checking if a new (of up to 8 ) BankStick has been connected to the core module, I’m only checking a single BankStick with each USER_Tick execution. I’m using a counter which is incremented and reset if >= 8 each time my BankStick handler is called, and this counter addresses the BankStick which should be checked. This easy method reduces the execution time of USER_Tick dramatically, and therefore improves the overall performance of the application.
