USB connector on STM32F4
Hello there
im wondering why the stm core uses the small usb connector…i really like the normal USB connector on the LPC core this is more solid and im somewhat
scared to break off the small connector on the STM32F4 core…has anybody got a solution for this ?
cheers,
electro
does anybody know the schematic to connect a normal usb port ?
I have the same concern.
On my MBCV V2, I have cut off the other end (not the Micro side) and soldered a USB type B female socket to it that is attached to the case.
The solution I am going for now is this cable/adapter that TK suggests
http://www.reichelt.de/DELOCK-83183/3/index.html?&ACTION=3&LA=446&ARTICLE=126860&artnr=DELOCK+83183&SEARCH=DELOCK+83183
http://discourse.midibox.org/t/topic/18442
http://discourse.midibox.org/t/topic/18914
ive been looking at the schematic…it seems like there is no breakoutpin on the stm board for usb (or at least some of the pins needed for usb)…and in that way it makse sense that there is no usb connector on the stm core board itself
thanks for your reply eptheca… i will look into this !
I spotted this a few weeks ago
https://www.pjrc.com/store/cable_usb_panel_micro.html
Though it wouldn’t allow USB OTG
Yogi
In my MIDIbox FM V2.1 (with STM32F4), I used this adapter cable: http://www.ebay.com/itm/50cm-USB-2-0-B-Female-socket-Printer-Panel-Mount-to-USB-Micro-B-5-pin-male-cable-/291006031451?pt=LH_DefaultDomain_0&hash=item43c14fa65b
Much less risky than desoldering SMT, and it has worked fine so far. Of course, this assumes you’re only using the STM32F4 as the USB Device, i.e. plugging it into a PC.
ooh wow
these are very very good…cheers guys …thank you so much !
can it not be used to power a seqV4 ??
yes you can power the SEQ V4 over USB, but use a powered Hub, the computer socket will not work
I have tried one of these adapter cable and it powers my SEQ directly from the USB port on my Macbook Pro, no powered hub is needed.
It all depends on how much current the USB port your connector it to can provide.
yes, that is true, some USB 3.0 ports deliver 900mA, which could be enough
the standard usb 2.0 port delivers 500mA, which is not enough for a SEQ V4, but it also depends on the CS, LED’s, LCD’s etc.
thanks guys…ik know about the powered hub…i got three of those
just wondering if this cable can be used to power a full seqv4 with leds lcds wilba CS and midi IO boards and iic module
