trgger layer LED's
I’m having some trouble w/ my trigger layer LED’s.  When I select A, nothing is lit, when I select B, A is lit, and when I select C, B is lit.  I’ve checked my wiring, and it is fine.  The way I’m trying to configure this SR is..
0 -play
1 -pause
2 -Stop
3 -A
4 -B
5 -C
6 and 7 are the 1-16 17-32 led’s
Everything works fine except for the trigger layer.
I tested all of the wiring w/ my multimeter, and it checked out ok
So, just as a test, I switched it so that
0 -A    (play led on my panel)
1 -B    (pause led)
2 -C    (stop led)
3 -play
4 -pause
5 -stop
and have the same results.  the A button lights up when I press play.  The play button does not light when I press A, Play lights when I press B and pause lights when I press C
This is the section of my ASM file
;; OPTIONAL! see CHANGELOG.txt
DOUT_ENTRY TMP4, 5, 5, 3 ; Triger Layer A LED
DOUT_ENTRY TMP4, 6, 5, 4 ; Triger Layer B LED
DOUT_ENTRY TMP4, 7, 5, 5 ; Triger Layer C LED
DOUT_ENTRY TMP5, 0, 5, 0 ; Play LED
DOUT_ENTRY TMP5, 1, 5, 2 ; Stop LED
DOUT_ENTRY TMP5, 2, 5, 1 ; Pause LED
DOUT_ENTRY TMP5, 3, 5, 6 ; Step 1-16 displayed
DOUT_ENTRY TMP5, 4, 5, 7 ; Step 17-31 displayed
Thanks for any help
Hi Wicked1,
this seems to be a documentation error - the trigger layer LEDs are located at TMP4,4 … TMP4,6
Bes Regards, Thorsten.
Thanks,
That fixed it.
