Traktor Flight Case
I’m in the process of building a case to my Traktor controller. It’s going to be a robust flightcase (plywood and alu-profiles):
More pictures @ : http://www.gavle.to/~henrik.m/box/index.html.
The bottom part of the case ia aprox 280*630*150mm, the lid aprox. 40mm heigh
Going to be the home for this: http://www.gavle.to/~henrik.m/traktor.jpg
I have two questions:
  1. The case feels a bit to high right now, should I try to lower the bottom part to get a more confortable working height ?
  2. Any suggestions how to make the contacts for 230V~, midi in/out, possible line in connector etc ? I want the conectors to be protected during transportation, no risk for dust dirt etc. How to ? somekind of hatch ?
Other thougts ?
Best
Wise
You could put the connections on the front panel( up at the top out of the way).
Ahh, good sugestion !  :slight_smile:
But how about the 230V~ ?
/Wise
you could use a neutrik powercon on the top…
http://www.neutrik.com/content/Products/products_group.asp?level2id=204_54471
why don’t you buy one ready-made?
http://www.illusiana.net/gallery/view_photo.php?set_albumName=Midibox-design-photos&id=DSC_0069
I have looked around for a ready-made-case, but with no luck finding one that will fit my panel. And I don’t want to redesign the panel. And well.. Is it DIY it is DIY  :wink:
Still have’nt found a good sollution for the power connector. Thx Tl for the neutrik powercon, good, but not perfect. To big and uggly to stick up from the panel i think..
/wise
