traktor controller design
not 6cm , 10cm, i thing it’s enough,
why only layout for t2 ?
because T2.6.2 is more stable than T3 ( native instruments forum ! )
why 1: 1 copy of T2 ?
why not, i have big fingers and i thing my layout looks like a real mixer,
this is my first prototype, everything can happen in the future,
encoder is from a double cd player remote unit, sometimes very cheap at ebay, it’s an alps encoder
best regards ranger930
new layout with some led’s,
tip: use low current led’s to reduce the current at all ( smaller psu )
best regards
ranger930
very nice layout :slight_smile:
but why u dont make more place between the pots ???
cause when I´m mixing and turn for example the middle and high pot on 1 section at same time, i dont want to touch both fingers together…need more place for berzerking the mix :wink:
Regards
MTE
hi,
@mte
thrust me
it’s enough space between the pots,
it looks only on the pictures to small,
best regards
ranger930
okidoki :slight_smile:
Pioneer mixer spacing: 30mm between centers
Hi ranger930,
just wondering where you managed to get the jog wheel from - I’m still looking for an online supplier…
  • Adam
hi meeshka,
encoder is from a double cd player remote unit, sometimes very cheap at ebay, it’s an alps encoder,
i bought my very cheap, there are two encoder in one unit with caps !
or look at alps.de or alps.com
best regards
ranger930
some new photos:
backside with most pcbs
pcbs for potis and buttons
pcbs
backside of DIN PCB and adapter-pcbs with connector
best regards
ranger930
@tk:
hallo thorsten,
sorry ich weiss, eigentlich in englisch, aber trotzdem kurze Frage !
ich habe folgende hardware eingeplant:
2 Core Module, 1x mb64 und 1xmb64e,
an das mb 64 Taster und potis und an das mb 64e die encoder, das datawheel und die Taster.
Ist es eine Frage der Prgrammierung, ob ich irgendwo einen button oder einen encoder anschliesse,
ist das Betriebsystem in Lage dies zu steuern ?
MfG
ranger930
Du kriegst doch alles in die MB64E-Firmware unter, die neue Version unterstüzt ja jetz auch Pots :wink:
1 Core für deine Box reicht völlig
MB64E = 128 Digital Inputs,128 Digital Outputs und 64 Analoge Eingänge
Grüße
MTE
Hallo,
@MTE:
danke, das wusste ich bislang nicht, wieder was gelernt !
aber was ist jetzt mit der dieser Frage:
MfG
ranger930
hi!
Ja klar. Es ist eine frag wie du MIOS einstellst, sprich welchen Encoder Eintrag du in die mios_tables.inc setzt, BEVOR die firmware kompiliert wird und in den PIC gespielt wird.
Mit 64E bzw dem C Interface sind ziemliche wilde und eher komplexe sachen machen.
Aber dafür reicht im Normalfall ein Core aus.
Siehe hier: http://www.midibox.org/forum/index.php?topic=3852.0
Das ist mein Controller der immer noch nicht fertig weil shcon wieder umgebaut ist :wink:
Grüsse m.
Ja, es ist in beiden Fällen möglich, mit der MB64E (in Assembler) oder wenn du es in C programmierst…
ich habe ja das gleiche mit meinem Traktor-Prototypen auch gemacht -> http://www.midibox.org/forum/index.php?topic=6871.0
Zuerst nahm ich die MB64E Firmware, wollte aber unbedingt mit den Encodern “pitchbenden”.
In Assembler bekam ich das nicht hin, da schickte mir Wild Weasel einen Ausschnitt seiner Firmware, die in C geschrieben ist, damit funzt es wunderbar.
Eine Frage :
Baust du noch Encoder-Jogwheels in deine Box ?? Dann würde ich die Firmware in C definieren
Grüße
MTE
klingt ja gut !
ich habe vor C zu benutzen, habe in der Vergangenheit schon einen 8051 mit C programmiert,
assembler habe ich auch mal gelernt, aber C scheint mir bei meinen bescheidenen Fähigkeiten etwas leichter zu sein,
Ja !  Jog wheels soll mein Controller auch noch bekommen, ich hatte ja mal an Kontrol DJ ne message geschrieben, mit der Bitte um Info’s
bez. Jog wheel, aber eine Antwort bekam ich nie,
habe irgendwo mal gelesen, das jemand eine Stückliste des kontrol dj haben soll,
habt ihr das auch schon mal gelesen ?
mfg
ranger930
ne, leider net, würde mich indem fall auch brennendst interessieren.
Zu deinen Jog-Wheels :
Wir könnten Dir welche fräsen wenn du magst, ich hänge grad am layout für meine (siehe Attachment unten)
da hab ich mich auch schon für Acryl entschieden…die Symbole werden wie bei meiner SID-Frontplatte eingraviert, lackiert etc..
Grüße
MTE
wir gross würden die dann werden ?
meine dürfen nicht grösser als max. 110mm Durchmesser sein,
das Jogwheel sollte so aufgebaut sein wie bei control dj, wahrscheinlich ist unter der beweglichen Platte ein Encoder von alps,
man könnte ja einen turntable nachbilden, war so meine Idee !
Der äussere Rahmen könnte auf der Frontplatte sitzen, der Encoder in der Frontplatte festgeschraubt sein und auf dem Encoder die bewegliche Scheibe ( gummibeschichtet, wie bei einem TT )
ich denke der Bedarf hier im Forum wäre auch da ,
mfg
ranger930
Also meine Jogs werden genau 120mm im Durchmesser, ich nahm ne CD als Vorgabe…
Stärke 10 mm, somit sind sie schön massiv…das mit dem Turntables war auch schon eine Idee aber das wird mir zu groß, wär aber vielleicht mal ein Versuch wert… :slight_smile:
Montiertechnisch solltest du das selbst für dich rausfinden, da jeder Encoder ne andere Bauart hat (Schaftlänge, Durchmesser, etc)
Als Jog-Endcoder schwöre ich auf die Dinger von Pollin…sie sind aus sehr massivem Gußeisen oder Alu (keine Ahnung was das jetz genau für ein Material ist), man kann oben zentriert eine 2-3 mm bohrung setzen um darauf das Jog zu montieren…
Bei meinem ersten Prototypen habe ich einfach 8 CD´s übereinandergeklebt, zum Auflegen sehr gutes Gefühl…hatte vor 3 Wochen auf ner Outdoor Party von uns das Gerätchen knapp 20 Std am laufen…flutscht :slight_smile:
Male dir einfach mal auf wie du es dir vorstellst…nimm ein paar cd rohlinge und fühle wie sich das gewichtstechnisch anfühlt (kommt Pioneer Jog-Wheels sehr nahe)…wenn du andere Encodersorten ausprobieren willst, bei BOURNS kann man samples ordern :wink:
Grüße
MTE
i’m back again with more pictures and the first 30 buttons for the loop sections are working !
@MTE
das Display ist echt super, danke nochmal !
best regards
ranger930
gern geschehen…sehr saubere Arbeit !!
kriege diese Woche auch endlich meine Reichelt-Teile, dann werd ich meinen Traktorizer parallel mit dem Sid fertigbasteln *freu :slight_smile:
ich denke ich werde Dich dann nerven in Sachen C-Programmierung…wären nur ein paar kleine Sachen…hast du zufällig ICQ ?
Grüße
MTE
