TKD Motorfaders
Hi.
This morning I have received some samples of the TKD MLA-6100 series motorfaders http://www.tkd-corp.com/02_products/pdf/p02_MLA_e.pdf
I have both the 60mm and 100mm versions so once I have built my MF module I will feed back on how (if) they work.
Has anybody else tried TKD faders? Hopefully they should work as they don’t use coreless motors…
I have no price for them yet but hopefully as they are “Low Cost Motorfaders” they should be cheap  :slight_smile:
Thanks
Phil
Any update on these?
Regards,
Wayne
Hi Wayne. Sorry I missed your post.
I’ve been pretty busy with other things so my motor fader testing has gone on the back-burner…
Cheers
Phil
… welcome to the club  :smiley:
I know, instead of a LIFO todo list like TK’s, I sometimes think that mine is controlled by /dev/random …
hello
I’ve been playing around with alps faders recently, using 32khz pwm to keep them quiet, at slow speed they are not that smooth, very uncertain. i am not sure as to the reason? it might be the fader is a bit warped? or the pwm is distorted ( i have no oscilloscope to check)
The tkd MVH2-6101 are aprox £50 ( from what i have heard) I wonder if they are more smooth and even and better made? the alps i have were aprox £25. i may try other frequencies and higher voltages to give the PWM more bite. my fader is rated at 10v 800ma , i am using 10v as my supply into a h -bridge. As i am using pwm, maybe i can up the volts to 12v? as long as i do not give it 100percent duty cycle. that may help give more bite and power at lower speeds:? shall give it try.
wow, did you get a free sample from tkd?
… which Alps are you talking about precisely? N-Type, K-Type or K-Type CP?
Greets, Roger
Greets, Roger
hello
they are RSA0N12M9. 10cm. the pdf is not the clearest but here is a link.
http://avpg2.homepage.t-online.de/alps/PDF/RSA0N12M9_RSAON12M9_10K.pdf
