Album by TK.
The prototype consists of untreated aluminium.
I prefered this option due to the faster delivery.
The final case will be black anodized aluminium
From the other side - the case looks very robust!
Note that there are some “movable slides” (or how you would call them) which would allow to mount the frontpanel with screws.
This picture demonstrates the construction system nicely.
There are 4 spacers of Wilba’s MBSEQ Frontpanel which are a bit too much outside so that the case cannot be closed perfectly.
But don’t panic…
…these spacers can be removed w/o disadvantages!
The MBHP_CORE_STM32 mounted on 20 mm spacers inside the case - it fits!
Was it Nils intuition to place the mounting holes below the USB socket so perfectly? ![]()
Closed case
And when I’m writing “closed”, it’s really closed. Perfectly fitting frontpanel!
Next step: creating the backpanel
Temporary it’s possible to use the case w/o backpanel - the case construction doesn’t require it for holding the remaining panels together.
MB6582 + MBSEQ together.
MBSEQ + MBSID Vintage Case together
Front view
Due to special request: this picture shows the slots of the sidepanel
Preparing the core module for mounting
I glued 5mm standoffs to the front mounting holes of the MBHP_ETH module - no screws can be used, but the construction seems to be stable
3mm holes have been drilled for all modules. The holes have been deburred with a 5mm drill
After all modules have been mounted…
Finally a closed case - hurray!
Note that this backpanel has some layout errors as explained in the forum thread.
E.g. due to slightly wrong dimensions, the case isn’t completely closed (upper screws don’t match with the screw threads)
Another view of the backpanel - I consider to swap the positions of Ethernet socket and SD Card/AOUT Extension slot, since internally the SD Card socket clashes with the socket of a LCD
By flipping the SD Card PCB inside the case there is no collision with the frontpanel LCD connector anymore.
Disadvantage: the SD Card has to be inserted upside down (but thats acceptable for me)
Due to special request: there is enough clearance between SD Card and the expansion port - it’s possible to change the SD Card w/o disconnecting the D25 plug.
Remote controlling my MIDI gear with Pianist Pro (running on an iPad) via MBSEQ.
The OSC port of MBSEQ is connected to a WiFi router.
