OK I have decided to put all my effort in to design and build a Midibox64. It is the best solution I have found by far to use as a controller for Ableton Live.
I thought it would be nice to document the design, build, and testing of a Midibox as it goes on over the next few months. I am going to post updates here
as I go and hopefully I will have a beautiful Midibox in a couple months time.
The purpose of my Midibox will be as a live controller for Ableton. It will not be the most original Midibox around but it will be very functional for the way I work.
The specs of the box are as follows:
55 rotary pots
9 slide pots
64 buttons
46 LED’s (16 of these 30 are on full-time, no DOUT)
Blue 16x2 LCD
Obviously this requires:
(1) Core Module
(2) AIN Modules
(2) DIN Modules
(1) DOUT Modules
I purchased these from SmashTV’s place late last week.
I did a little rendering of the layout of box and it will look like this:
Image removed due to possibly malicious content. Download at your own risk, it contains a strange script. - stryd_one
http://www.alphazone1.com/midibox/midibox10sm.gif
http://www.alphazone1.com/midibox/midibox10.gif
here’s a link to a bigger pic
I am an audio engineer and I have a lot of resources available at work. This will hopefully help me realize my goals.
The first major decision I made was that I decided to protoype pcb’s that will be modular parts that will hold the components.
1.The “4 pot board”
Since my layout works around rows of 8 pots will re-use about 12 of these 4-pot pcb’s. I am using 9mm panasonic panel mount pots.
here is the board layout:
http://www.alphazone1.com/midibox/pot-board.gif
- The “4 switch board”
This will hold ITT/Cannon PHA (Alps SPUJ) type momentary push-buttons. It will also hold 4 leds that will indicate the state of each button.
I haven’t finished the layout of this one yet. This pcb will piggyback on the pot pcb using plastic standoffs. This will allow me to align the switch
board correctly with the front panel (which the pot board is already connected to by use of the panel-mount pots).
As far as the layout of the panel itself it is fairly staright-forward. There are 6 “clip” channels and 2 effects return channels (a “clip track” is just ableton-speak for an audio channel in Ableton’s session view).
Each clip track has…
8 pots - 4 for insert effects parameters, 2 for effects send levels and 2 for hi and low EQ
8 buttons - 4 for insert effect parameters, one each for play, stop, cue, and A/B select
60mm fader (for level of course)
Each of the 2 FX tracks has…
4 pots - 3 for send effect parameters and one for send level
6 buttons - 4 for send effect parameters, one for cue and one for A/B select
60mm fader for send level
Globally there is:
Crossfader - fades between outputs A and B
Clip Up and Down buttons (the two red square buttons). These will be used a lot. These are used to select the clip you want to play.
Record button (to record the set into Ableton while it’s going on)
Tempo dial - I have this cool led light-pipe dial I used on a project at work that I am giong to use as a dial that controls tempo in Ableton. It will only
stick out slightly above the surface of the panel to avoid accidental movement.
Headphone cue level knob
The Midibox will have an M-Audio Firewire Audiophile built into it. There will just be a couple sets of audio outs and and IEC jack on the back of the unit.
OK that’s it for now. I will update soon when parts come in and pcb’s are made this week…
Brian.
