Album by Antichambre
Hardware Advanced Arpeggiator
The HAARP CS in eurorack version with the Core Module.
/topic/21141-the-haarp-an-hardware-advanced-arpeggiator/?do=embed&embedComment=184453&embedDo=findComment#comment-184453">
The HAARP, The Front Panel Layout
The HAARP Prototype #001
CAN Transceiver added.
HAARP desktop version
All HAARP PCBs
All HAARP PCBs
dipCoreF4 Euro Assembly Test
The phoenix screw terminal is not necessary for euro version.
A common Euro power connector is placed instead, I'm waiting for it.
[Image not found: IMG_1493.JPG]
dipCoreF4 Euro version assembly test
The white spacers are 6mm but can be reduced to 2 or 3mm…
The global depth with connectors is less than 50mm!
dipCoreF4 Euro version assembly test.
The HAARP Desktop Case Prototyping
Milled Top Part 1mm thick
The HAARP Desktop case prototyping.
Milled bottom part 2mm thick.
After bending.
Assembly check.
Assembly check.
Assembly check.
Assembly check.
Assembly check.
Assembly check.
White paint!
White paint…
paint…
it’s the kind of moment that I don’t like, when you have to be patient so as not to destroy a working day.
Let it dry!..
