I have a Tascam FW 1884 DAW Controller with two FE-8 Extenders for which there is no driver support anymore (the device uses FireWire). As I mainly use the control surface I want to build a MidiBox core into it to continue using it.
I have built a MidiBox remote before and just love the platform.
First I thought about using the new Motorfader core and a PIC Core per 8 faders but when looking into the boxes the PCB’s are so nicely accessible and separately wired I thought it might be possible to reuse the motorfader circuitry. Luckily I have the service manual and layout of the device but sadly I’m not very savvy in these things.. I found out theres some 10bit A/D’s working on the PCB, maybe theres a way to make a MIOS PIC talk to that? Or maybe with the new platform?
Here is some screenshots of the layout, it also contains the IC numbers, I wouldn’t want to upload the whole service manual but tell me if you need to see other areas to tell me more.
This should be the touch and input stage I guess
And this is the motor driver chip it seems
There is not much more on the fader PCB so this is the data bus / PWM signal the PIC would have to work with.. If it can?
I’d be happy about any hints, maybe I don’t have to rip out the whole fader PCB (to which the faders are soldered
) then it would be a totally clean heart transplant so to speak.
Cheers and keep on MidiBoxing everybody ![]()
Normen
