Ok, I know this project seems a little too much and it’s probably near impossible of not impossible to do, but I want to try it anyway…
I want to build myself a DAW controller based on the design and layout of the SSL Origin console.
I don’t need such a big controller and its in no way logical to build one and put this much time in this project, but I just love the idea of having a nearly two meters wide mixing console as the centerpiece of my studio.
The plan I created in the last month:
The controller should consist of 32 channels with one motorfader and 38 buttons/ potis each.
On top of that is a mastering section with 8 additional Return/Send/Bus faders, wich will be normal 60mm faders and some basic daw control buttons like play/stop/record.
The channel strip consists of the SSL E series eq and 8 additional potis controlling the different Bus channels.
On the DAW side I want to build a template with all plutins loaded and with the right mapping, so that I can start working on the console immediately.
Now to the hardware:
Adding all channels and the mastering section there will be a total of 1246 buttons, faders, or potis and 32 motorized faders.
I’m still quite new to this whole universe, so hopefully somebody could look over my thoughts and correct my if I’m (most likely) wrong.
I need to read 1246 buttons/faders/potis.
I chose the CORE_STM32F4 as my core and want to expand the inputs using the AINSER64 Module.
I read there is a way to connect more than two AINSER 64 to a STM32F4, but I didn’t quite understand how this would work.
I found a forum post writing about three AINSER 8 connected to a core. Is there the possibility to connect even more?
If I think of two AINSER 64 per core, this would mean I can read 128 buttons, etc with one core.
So I would need 10 cores for the not motorized knobs etc alone.
Is this possible? Can I connect 10 cores all via usb to my pc and program them to one big controller?
On top of that I would use the MF module for the motorfaders. Using 32 motorfaders I would need four Mf modules.
Since I think there is the possibility to cascade multiple MF modules there would only be one USB running to the pc, right?
I have many more things planned and a truckload more of questions, but I will just leave this here as it is and get to the other questions at a later time.
I know this is a HUGE project - especially for a newbie and I don’t want to confront anyone, or come across as arrogant.
I simply cannot get this out of my head and usually the best way to get it out is eventually just starting the project.
This will surely take a long while to be build and programmed and I already have some friends and family helping me with designing, soldering and programming.
I’m really looking forward to this project and cannot wait to show my process here.
Sincerely
Frederik
