I don’t want to sound lazy but please could you paste me an example code if you have one so i can put your explanation to code. I’ve never tried programming beyond the Mios functions
Edit: don’t use this yet… I gotta check one more thing…
I went to try this and found that TK left you a hint:
j5_dout.inc:
J5_DOUT_Init
;; disable the ADC which allocates the analog pins
;; removed
;; movlw 0x07
;; movwf ADCON1
;; turn on the output driver of PORTA and PORTE
;; (note: if you want to use some of them as input instead, just set the appr. line to "bsf TRISx, x"
;; first 6 pins reassigned as AINs
bsf TRISA, 0 ; Pin RA.0 = ain
bsf TRISA, 1 ; Pin RA.1 = ain
bsf TRISA, 2 ; Pin RA.2 = ain
bsf TRISA, 3 ; Pin RA.3 = ain
bsf TRISA, 5 ; Pin RA.5 = ain
bsf TRISE, 0 ; Pin RE.0 = ain
;; last two are still DOUTs
bcf TRISE, 1 ; Pin RE.1 = output
bcf TRISE, 2 ; Pin RE.2 = output
return
Then in main.inc:
USER_Init
;; initialize J5 for driving LEDs if enabled
#if ENABLE_J5
call J5_DOUT_Init
#endif
;; initialise AINs. BE SURE TO EDIT j5_dout.inc !!
movlw 0x06
call MIOS_AIN_NumberSet
call MIOS_AIN_UnMuxed
Then throw your stuff in
USER_AIN_NotifyChange
;; your code here
return
I *think* that will work. Check my work, because ****ing this up can result in a short and nuked PIC.
Okay there was one thing I wasn’t sure I’d gotten right, and it turns out that it depends on which PIC you’re using. In the code above, right at the top, is this:
J5_DOUT_Init
;; removed
;; movlw 0x07
;; movwf ADCON1
If you have a 4620/4685/etc (newer chip) then make it this:
J5_DOUT_Init
;; AN0...AN5 AINs, and AN6,7 DINs
movlw 0x09
movwf ADCON1
If it’s a 452 … uhm… Pretty sure that we want
J5_DOUT_Init
movlw 1 << ADFM) | (1 << ADCS2) | 0x09
movwf ADCON1
Oh, in case you didn’t notice, you have to use the AINs for the first 6 pins on the port, and the remainder can be DOUTs. BTW, if you want to use more or less pins, these ADCON1 values will change. You can find tables in the PIC datasheets that describe what ADCON1 values will do.
