Anyone tried to MIDIfy any vintage speech synth chips using a MIDIBox core? I’m thinking of the old SP0256 and Votrax chips that used to be available as addons to personal computers in the '80s, and were apparently also used in some arcade games.
I know about the SpeakJet project. I’m about to build one based on TKs new version of audiocommander’s original code, tweaked to run on the LPCXPRESSO board. I was just wondering if anyone had done something similar for any older chips.
I have the datasheet for the SP0256-AL2, and it looks like getting it to output basic allophones wouldn’t be too challenging, for someone who knew what they were doing (unlike me). It doesn’t seem to have any information about pitching the oscillators though.
The Votrax also sounds intriguing. There’s apparently a patent application from Kraftwerk (no less) for a circuit to add MIDI control for this IC. I have a suspicion it’s what they used on their remake of Autobahn from their The Mix album.
The MBHP_CORE_LPC17 would be powerful enough to handle speech synthesis by itself - in background (because it wouldn’t really time consuming work @ 120 MHz…)
It even supports a I2S output for an audio DAC at 48 kHz (stereo)
Problem: I don’t know free (open source) code for such a synthesis, and developing it wouldn’t be a task of one evening…
Interesting. I was more interested in the sound of those vintage chips, but under MIDI control. Having said that, an entirely software-based solution, would also be quite cool. Would you envisage that being possible within a MIOS framework, TK?
Incidentally, did you get my pvt message re. the the SpeakJet circuit?
That does sound cool. I guess if you were going strip it down to MIDI-controlled phoneme synthesis, you could probably strip out the majority of the quoted 1.4MB of program code, too, leaving just the phoneme tables and formant engine.
Never done any hardware programming in C though, so I may be talking out of my hat.
The LPC17 is running *much* faster than an Arduino (although the LPCXPRESSO is cheaper), so that more complex algorithms can be used which should lead to higher audio quality.
Just been listening to some of the Cantarino demos. That sounds great! Not very understandable, but lovely and crunchy. Would be cool to hear that running from a MIDIbox, under MIDI control.
You say ‘higher audio quality’, Thorsten, but I quite like the crunchiness of low-quality speech synthesis (hence my interest in vintage speech ICs)
Just out of interest, is it possible/advisable to output audio directly from the LCPXPRESSO, or is some kind of external DAC required?
Adding some distortion would be simple as well
Yes, there are multiple possibilities:
using one or more PWM outputs to generate the sound exactly on the same way like on SpeakJet (and other speech chips)
using the inbuilt DAC - it has only a single channel at 10 bit resolution, available at pin J5A.A3 (P0.26) - the result should be more crunchy than on a SpeakJet
using an external I2C stereo DAC
Maybe the first option isn’t that bad, especially since it would allow to generate different sounds in parallel on multiple outputs to simplify the Fx chain
Going back to the hardware approach, I’ve discovered another speech synth chip that seems to have a nice voice, and is quite well documented. It’s called the Soundgin, and it seems to be quite like the SpeakJet in some ways.
The soundgen is very close to the speakjet, but is geared more towards general synth as well was speech. I’ve got a demo board around here, (somewhere). The synth design is modeled after a SID, I think, but of course does’t sound as good. Had thought about modding the speckjet project for a soundgen, but my project ‘to do’ list is already very long.
