Well then the hw file is fine I presume. Maybe double check the cable between the core and the cs? there is a j1 and a j2 on the cs board but i guess you got that right. No shorts or bad soldering on the cs?
Also check the shift register ICs (correct alignment and type), installing wrong or misaligned ICs might cause the behaviour you are experiencing. Please also check your resistor networks, as these are used to pull up the digital ins.
Ok…RN solders seem fine, continuity is fine with the IC pins too…
There is continuity between all ground pins of the RN, but no continuity between RN ground pins and CS board ground…For eg, there s no continuity between C1 “negative pin” (I know C1 is not polarized but this pin is connected to IC 1 ground and thus to CS board ground) and common pin of RN1…
I’d like to know if this Is this normal before soldering a cable to have continuity between RN common pins and CS board ground and potentially ruin my MB even before it has worked !
The 1 000 000 000 $£€ question is: Do all resistor network common pins have to be connected to CS board ground pin ??
If I’m not mistaken, the common pins of the resistor networks are not to ground, but to Vcc (+5V) they are _ pull-up _ resistors for the digital lines. The schematic of the CS is down here. Don’t solder it to ground, you might short & toast your power supply. [Want my paypal account for the 1 000 000 000 $£€? :lol: ]
The MBSEQ_BM flie holds the bookmarks, I don’t think it is critical. Maybe double check the PATTERN button, is there a smal short or something, is the button flakey? Your first weird screen is what you would get when pressing Pattern.
The ones you linked are the correct type, as long as Reichelt delivered the correct ones.
There are two (well three, but dual terminator is not so common I think) types of RN, one where the pins are isolated into individual elements, the other has one common/bussed connection and are used for pull-up/down resistors.
A picture = 1000 words. It can save a lot of time for those helping you troubleshoot to check if your soldering is sloppy, maybe the switches you used can be installed sideways etc. etc.
Great, but maybe you can be more specific? I can’t see how your +5V connection was missing, apart from cold solder joints, but you said above that the soldering was fine.
