[SOLVED] SD Card error -2
[8269.582] [disk_initialize] error while checking for SD Card (status 0)
[8269.582] [disk_read] error while reading sector 0
[8269.582] [FILE] Failed to open root directory - error status: 1
[8269.582] [sDCARD_ERROR:-2] DFS_GetPtnStart failed to find partition
[8269.582] ERROR: SD Card Error -2 (FatFs: D  0)
[8270.596] SD Card disconnected
Can someone please give me a description of this error or where to find one.
MIOS32 successfully connected to the SD Card, but didn’t find a FAT16 or FAT32 filesystem.
You can format the SD Card with your computer, or (maybe better) with the “sdcard_format” command in the MIOS Terminal.
Hi Thorsten,
thanks for your reply. Now I’m getting a formatting error:
[48347.313] sdcard_format yes, I’m sure
[48347.315] Formatting SD Card…
[48347.315] [disk_initialize] error while checking for SD Card (status 0)
[48347.315] [GET_SECTOR_COUNT] Count is 0
[48347.315] Formatting failed with error code: 14!
[48348.207] SD Card disconnected
So I made:
dd if=/dev/zero of=/dev/sdb
fdisk …
mkfs.vfat /dev/sdb1
Same output, also with a different card.
Kind regards,
Uli
Check all the connections between card reader and core board - that could be a cause if a known to be good card isn’t recognized properly.
Guess I somehow screwed my cardreader, by connecting it twisted. Another one works fine.
Thanks folks,
Uli
Fine! :slight_smile:
