Snapshots differencing by Parameter Groups
maybe this has been coming up before and theres a solution.
To the ones who might know one, please shed some light.
Is it possible, to dedicate snapshots to certain groups of parameters?
Goal would be, that (to be defined) Parameter Group 1 gets an own snapshot
as well as Parameter Group 2 and so on..
Thanks in advance,
=FFW=>
too difficult at my side…
However, if I would provide access to the “no_dump” flag in the .NGR file, you would be able to enable/disable the flag for the affected events before restoring the snapshot via “exec_meta SetSnapshot <number>”, “exec_meta LoadSnapshot” and “exec_meta DumpSnapshot”.
Hmmm,
as i understand it, this is a solution, isnt it? And not a bad one. Would you provide access to the flag (!) then?
The case would be to have three Parameter Groups with their own snapshots (track send amounts / track device parameters (cutoff etc.) / return-feedback matrix). As i understood it, one will enable/disable the respective flags for there parameter groups right before _restoring_, as when saving a snapshot, all parameters available get stored anyways (no matter if they have a no_dump flag)?
Cheers (and thank you),
=FFW=>
Yes, this is the solution.
The SET_NO_DUMP command is part of the V1.032 firmware that I released yesterday.
i´ll try to put it to life and report back!
thank you for being like that. always.
