Hi
Im making progress, and now i have a new question:
The MIOS bootstrap newbie site says:
the Newbie method: plug the slave PIC into the master core socket and program it in the same way like you did for the master PIC. Only differences: you have to pick another .hex file, and you need to change the device ID. This has the advantage, that you can also ensure that the software is installed properly with the master core/SID as a “reference”.
What other hex file is that. I cant find a special SLAVE HEX???
Thanks
/Carsten
[edit]: hi TK could you edit the title of this topic, it is of cause slave and not slace
