there are 2 detented encoder modes provided by mios;
MIOS_ENC_MODE_DETENTED and
MIOS_ENC_MODE_DETENTED2
In the mios_tables.inc of the sid app., all the encoders are defined as “detented2 encoders”. You could try changing the encoder mode to “detented”, build a new sysex and upload the modified application. Don’t know for sure if this will fix it but i would try it.
first open the mbsid project file in MPLAB IDE, then open the header file mios_tables.inc . Make the changes in this file like i mentioned above. When finished, build the project (F10 in MPLAB i think), and then when there are no build errors, convert the hex file you just made to sysex with convert.bat. This sysex file you can upload in your midibox.
it is possible that i have it wired wrong, its a bourns, currently its wired like the diagram with the middle pin as gnd.
Center pin is ground on these…
i also noticed speed settings? should i fiddle with these?
Yes! You are on the right track here…
From TK’s SID 1.5 release notes
Rotary encoders: CS_MENU_ENC_speed_VALUE allows to define the speed setting for encoder #2-#15. Although I’m using non-detented encoders, I prefer following setup: encoders in MIOS_ENC_MODE_DETENTED2 mode (reduces the resolution), CS_MENU_ENC_speed_VALUE set to 3 (by moving the encoder faster, you can sweep over the whole value range)
The best setup depends on the used encoder, just try different settings.
I have not used it, but enc_speed_v1_3.zip from MIOS downloads/test apps/ lets you try the different encoder modes with minimal effort.
