At a quick glance, I’d make the comment that you should use SRIO service prepare to set up the dout, and service finnish to read and process the din.
By reading and writing in the background loop your setting and reading the ram image of srio transfers but you need to sychronise with the actual transfers that occur each millisecond.
Thanks! I’ll try using the SRIO functions and see how that goes.
Edit: how does this look?
void APP_Background(void){
u8 shift = 0x01;
u8 i = 0;
u8 j = 0;
while(1){
shift = 0x01;
for (i=0;i<8;i++)
mios32_srio_dout[0] = shift;
for (j=0;j<8;j++)
if(mios32_srio_din[0] & (0x01 << j))
//Note is on
else {
//Note is off
shift << 1;
The mios32 arrays in your code are still the ram values that get used, and are unsynchronised with the actual transfers.
If I was doing this the first thought is to set the DOUT pins in a routine called from inside:
// This hook is called before the shift register chain is scanned
void APP_SRIO_ServicePrepare(void)
and then read the DIN pins from a routine inside:
// This hook is called after the shift register chain has been scanned
void APP_SRIO_ServiceFinish(void)
In the repo Apps/examples is a 16x16 decoder app that uses another method: define an RTOS task that does the scan and calls the notify toggle hook. There are always very many solutions to a given requirement!
irq enable and disable is allready handled by the system. You dont need to call them when using these hooks .
you call noteon() and noteoff() on the pin state. This results in repeated calls on the same keypress (and keyoff!). You really need to call them only on a (debounced) transition!
There are various examples in the repo to study to see how these tasks typically get done.
