sid synth pic
Hoi,
ik ben de sid synth aan het bouwen.
Met 4xCore en 4xSID.
Stop je in alle SID’s dezelfde software?
Groeten, arjan
Ik bouw er zelf geen, dus ik kan het fout hebben. ;D
Voor zover ik begrepen heb stop je er dezelfde firmware in.
Maar…
Van de Ucapps site, SID Step B:
Preparation
After the firmware has been programmed into the PICs you have to change the default device ID (0) to the correct device IDs for the slaves. The first slave requires ID 1, the second slave ID 2, the third slave ID 3. This step can be done with MIDI-Ox, just connect only one core with your PC and send following SysEx string: F0 00 00 7E 46 [old device-number] 0D 03 00 [new device-number] F7.
Slave 1: F0 00 00 7E 46 00 0D 03 00 01 F7
Slave 2: F0 00 00 7E 46 00 0D 03 00 02 F7
Slave 3: F0 00 00 7E 46 00 0D 03 00 03 F7
Sometimes also the firmware of the master has to be configured, don’t forget to take a look to the main.asm file header if there are relevant options for your needs.
Er staat nog meer info, dus check de sectie over Step B en Step C voor de SID.
Succes.
http://www.midibox.org/cgi-bin/yabb/YaBB.cgi?board=troubleshooting;action=display;num=1065249859
