sid/core test
I’ve build 4 core’s and 4 sid’s, before i wiring it all together, i want to test 1 core with 1 sid, to make sure it’s working.
But how to test?
All voltages are ok.
I’ve connected a simple speaker to the sid.
What exactly load into the core pic?, i’ve downloaded midibox_sid_v1_6.zip
there are lots of *.syx files:
main.syx
setup_6581_slave1.syx
and so on.
First i’ve loaded the bootloader, and then main.syx
The lcd says mios v1.6…
What to load/do next?
Thanks
just follow the instructions under http://www.ucapps.de/midibox_sid_csB.html
(“Preparation of PIC18F cores”)
Don’t forget to update to MIOS V1.7 (thats only possible with the first level bootstrap loader during the first 2 seconds after power-on)
Sorry, I must read over it some how ???
Is it neccesary to connect a ampifier or sould i hear sound when i connect a little 8ohm speker?
Thanks
You should be able to power a little speaker just fine - my Sid blows my head off with headphones plugged directly into it - Tim
