Several questions on LC...
Regard!
I from Russia, on this beg pardon for my bad English
::slight_smile:
Hopes that You my questions not will shown too foolish,
"…I not magician, I only teach…"© (from old russian film a “Cinderella”) 8)
I wants to build MIDIbox LC, but on the strength of determined reasons I can not put (deliver) motofaders, from here questions:
  1. Possible put (deliver) usual faders instead of motofaders, and, if “YES”, must I change a microcode?
  2. What type Jog&Shuttle needed, and as its connect?
  3. I has found GLCD on KS0108 128x64 producer Data Vision Int. Correct it will work with core module in given desksides (I will have one LCD).
  4. Correct will work LC without USB and LTC moduls?
From Russia with love, Viktor
hi viktorG!
ill try and answer the q.s i have a.s for  ;)
if i understand you properly..
  1. non-motorised faders connect to AIN.so no need for MF pcb.s
  2. u want spring-loaded(return-to-center) ? it is possible..find YOUR solution(as TK says..its up to you now)
  3. im fairly sure you can use that GLCD on its own.
  4. again, you are right/
\cheers
To 2: in this case not, the host expects common incremental/decremental events. So, you can use the same rotary encoder like for the V-Pots, but a bigger knob (datawheel) should be prefered
Hi!
Enourmous thank you for Your answers…
Today has delivered last exam :stuck_out_tongue: and will now occupy LC in thick… 8)
One more question, from your permitions…
Comparatively notorious encoders…
I has found encoders company Bourns under the name PEC12-4220F-S0024.
Here is its feature:
Electrical Characteristics
Output …2-bit gray code
Closed Circuit Resistance …3 ohms maximum
Contact Rating …1 mA @ 5 VDC
Insulation Resistance …10 megohms @ 250 VDC
Dielectric Withstanding Voltage
Sea Level …50 VAC minimum
Electrical Travel…Continuous
Contact Bounce (15 RPM) …5.0 ms. maximum
RPM (Operating) …100 maximum
Environmental Characteristics
Operating Temperature Range …30 °C to +70 °C (-22 °F to +158 °F)
Storage Temperature Range…40 °C to +85 °C (-40 °F to +185 °F)
Humidity…MIL-STD-202, Method 103B, Condition B
Vibration …30 G
Contact Bounce …10~55~10 Hz / 1 min. / Amplitude 1.5 mm
Shock …100 G
Rotational Life…30,000 cycles minimum
Switch Life …20,000 cycles minimum
IP Rating …IP 40
Mechanical Characteristics
Mechanical Angle …360 ° continuous
Running Torque …30.6 to 204 g-cm (0.42 to 2.83 oz.-in.)
Shaft Side Load (Static) …2.04 kgf (4.5 lbs.) minimum
Weight …3 gm (0.1 oz.) maximum
Terminals …Printed circuit board terminals
Hardware …No hardware supplied
Switch Characteristics
Switch Type…Contact Push ON Momentary SPST
Power Rating (Resistive Load)…1 mA at 5 V DC
Switch Travel…0.5 +0.4/-0.3 mm
Switch Actuation Force…360 +153/-102 gf (5 +2.1/-1.4 oz.-in.)
It with switch…
Approach or no?..
Sorry for long post and bad english…
Forgotten to say…
Beside us (in Moscow) it cost 1.6 $…
