SetBankOfHwID
Hello,
I have two questions about this command :
1 - Is it possible to precise the type of hw_id in the meta command SetBankOfHwId ? I need it to change some encoders bank but my Dout matrix is receiving the instruction as well (which is not needed)
In example something like :
meta=SetBankOfHwId:ENC:14
.. to change only the bank of the encoder 14
..or..
meta=SetBankOfHwId:ENC:any
.. to change the bank of all the encoder and nothing else
2 - Second question, is it possible to change the bank of an item defined by a matrix ?
If i use…
meta=SetBankOfHwId:1001
…to change the bank of my RGB matrix led event i have an error in MIOS studio like :
ERROR: expecting 1 values for meta type in EVENT_BUTTON … meta=SetBankOfHwId
In other words: Is it possible to have a new instruction called SetBankfwd_id where we can use the same events like fwd_id ? :stuck_out_tongue:
(note that I’ve no time to give explicit help till September)
A .NGR script would give you much more control over the bank handling, especially the new “set_active” command.
http://discourse.midibox.org/t/topic/17687
Hope this somehow helps (although it probably didn’t answer your question)
