SEQV4 - Program Change Issues G1T1
Hey guys having an issue changing programs on a Mbase01 when I make pattern changes on the SEQV4…  Just to note i have G1T1 set for 64 steps and parameter “e” is program change… Program change 11 is entered on every step with the “All” option… Each of these patterns have been saved in the pattern folder then a Session Save before moving to the next pattern… When I select pattern B1 from A1 it fails to change to Program 47 and stays on 11.. When I check parameter “e” on B1 it sez Program 11…
Example…
G1T1
Pattern A1
Program Change 11
Track Name: Mbase r01
pattern save then session save
G1T1
Pattern B1
Program Change 47
Track Name: Mbase r37
Steps to fix this…
I have reinitialized the track to clear it all and no change… Program change works on the Mbase when I manually turn the GP1 knob when “All” function engaged… Strange thing is that my Minitaur works fine as it will change programs with Pattern changes…
Any insight appreciated…
Thx…
bri
Crickets chirping…
Really had no clue what mixer map did… Until now… It fixed my program change issue…
Thx to midilab for the help…
Aewsome box BTW!!!
Concerning Program Change: there is a newer (unreleased) MBSEQ V4 version which provides a track based program change selection.
Maybe you find it useful?
http://discourse.midibox.org/t/topic/17609
Thanks TK I will stick with what I have now as it is working… If things get ugly again then I will try that… I was ready to ditch the Mbase but not now…
