On 6/9/2017 at 2:18 AM, lis0r said:
I can get boards made.
Get boards made! ;D
Get boards made! ;D
Lisa - just wondering if you have a time scale in mind?
Im wondering, both for myself (ive never managed to get hold of a pcb set so far!) and also if i shouldnt be trying to make some cases for people in preparation.
Sadly my home printer is not really good enough for the task. Hopefully I will find the time to try printing out the layout elsewhere so I can compare it to panels, etc. early next week. Anything anyone can do to help regarding layout review would be much appreciated.
You should be able to print to a custom page. Just get some 11x17 paper and cut it 8.5 wide. set the custom paper as 8.5x17 and you have plenty of space to print it out. I have access to a large format printer and have printed what you have posted so far on 11x17 and it is scalled 10 to 15% smaller than it should be for some reason.
Hi Lisa,
Did you order yet or could you put me on the list?
Regards, Pim.
Hi all,
I’m afraid I’ve not ordered PCBs yet. Unfortunately, I’ve managed to misplace my control surface aluminium panel, so I can’t check if the holes will line up.
The most recent PDF file I printed above seems to be the right size - I printed it out and stitched it together, and the dimensions looked correct. If anyone else with a panel can do the same, and check the holes do line up, then I’ll be a bit happier that the PCB is right.
Lisa
Lisa
Would it be an idea for me to loan you a panel for checking?
Julian
I printed the PDF to 11x17 will test it for fit tonight.
More that willing to buy a PCB once finalized
It lines up well now with Julian’s case. There was a bit of an angle on the camera causing some of the pictures not to look 100% square but it lines up perfectly in person. I checked part sizing as well and it all looks good. Switches line up, encoders line up and ic sockets are spot on. The smaller switches line up as well. I did not have any of the larger square switches to test out. The ones with the switch caps that the case is cut for line up perfect. I have some large double sided copper clad if you post the artwork for the top and bottom I can make a test print. It might take me quite a while to get it done though I am short on spare time to do all the drilling in the shop for at least a week or two. Bathroom renovation under way currently eating up all my spare time… Might be faster to have them run at the fab house. I traced through the board a bit and did not come up with any errors.
I have not seen anyone asking about it on the Seq 4 designs but with the sid cs the lights flicker on startup. had an elegant RC delay solution that he posted in this topic:
Thoughts?
Hi all,
Sorry to disappear for a while. Everything has been going wrong for me! First I lose my front panels, and then work becomes a nightmare - the company I work for is being sold, and everything is looking very hazy from this point out.
I’m pretty sure the PCB files are good - I went over them in software and all the nets look good, they look right when I upload them to DirtyPCBs, and Gerald graciously tested the fit as best the image would allow. However, I can’t guarantee the boards are going to work until I’ve had a chance to build one up, which is where we come to the problem.
I don’t have any of the components, and I don’t have a core32 board. With the future of my job looking shaky, I can’t really afford to buy all the parts and the risk of ordering the boards. I could sell the boards I don’t need untested with no guarantee, but that’s not ideal, and I’m not overly happy with the idea.
If there’s a willing, trusted member of the midibox community who’s willing to abide by the restrictions set out by T.K., it could possibly be better for me to pass my project files on to someone who’s more able to see this through to completion?
Sorry I’ve been unable to help as much as I’d hoped - I very much understand everyone’s frustration.
Lisa
I would need to know what the restrictions are to be sure that I am able to comply. If so I have all the parts and proto board. I would be up for giving it a try.
No worries, this is a hobby for most of us and everybody understands your situation.
However, I also can offer my help. I have all the parts required - except the CS. Desperately trying to get it…
Im happy to do whatever i can to make this happen.
So many of us have been waiting on the CS boards for so long (as in years) and it feels that, thanks to Lisa, we are now so close…
The boards are probably not huge money, so i think i would be happy to buy un-tested, if others were also.
I lost enough money (as did others) on Marco’s deceit, in pursuit of a mbseq unit, that im happy to ‘risk’ a little on some honest boards that, i suspect, will be flawless anyhow.
Me too
Best regards
Both TK, and Wilba have approved of this.
There are a whole load of people waiting and waiting on the CS pcbs.
A confirmed good file exists, and has existed for years within the community.
Why is it that it cant just be emailed to Lisa (who, again, has TK and Wilba’s permission) for her to get some boards made up, and people to get on with building them?
Same situation as the other out-of-production boards (sammichSID, sammichFM, arguably MB6582). The folks in possession of the board files consider them to be proprietary. In the past, there has even been some really ugly hostility from those same folks toward a person who designed their own “clone” from scratch due to unavailability of PCBs or design files.
None of this is in the spirit of open design, and I’m reasonably sure it violates the letter of the MIDIbox license. OTOH, there’s really nothing that can be done to compel anyone to comply with the license, so its a bit of a moot point.
Lisa,
Would you be happy to post your work to date, so as it can truly be open sourced, and we can hopefully get some movement?
Again, i am happy to take some ‘risk’ - i would just like to see a project come to fruition! : )
Sorry for disappearing again - work is absolutely mental.
I’ve been given permission to do a single small batch of the boards, which with my board house is 10 boards.
If TK gives his permission, I’d be more than happy to open source the files. If someone else is willing to take over the boards under the same conditions, equally I’d be happy to pass them on, but again, permission from TK would likely be wise.
