Send a midi command when receiving a command
I finally got my Midibox NG up and running, but there are things that I have not manged to do (still in the beginning of my learning curve)
I would like to do the following: Send a midi command on MIDI OUT1 when receiving a different midi command on MIDI IN channel. I have explored this by using:
event_receiver id=3 type=cc cc=117(or any) lcd_pos=1:1:2 label=“MIDI recived”
with the aim of checking if I can recive a signal, however without any luck.
Any help would be appreciated.
Regards Arne
hi i also tried some events to Use my Bcf2000 also changed note’s.
only at the moment i dont have my BCF2000 at my side..
so this is a Example from a older topic from me…
EVENT_RECEIVER id=  1  fwd_id=SENDER:1  fwd_to_lcd=1  type=CC  chn=1 cc=1   lcd_pos=1:1:1  label=“Receiver%3i: %e”  PORTS=0000100000000000
EVENT_SENDER    id=  1                                   fwd_to_lcd=1  type=CC  chn=1 cc=2   lcd_pos=1:1:2  label=“Sender%3i/1: %e”  PORTS=0000100000000000
oke
here you see a example.
IF MB_NG gets a CC=1 on Midi in port1 it will send CC=2 on midiout1
and it will Forward some tekst on the LCD
hope this helps..
/Spirit
That did the trick.
Thank you
Regards Arne
