SD card STM32f4 error
I may have messed up my STM32F4 board.  I accidentally plugged the 74HCT541 in backwards while trying to power it up for the first time.  No lights came on.
I replaced both chips on the  core module and got the boot loader and LCD working.  I installed Midibox NG 1.032 but my SD card fails. :frowning:
From MIOS Studio 2.4.6 (here are the details)
[319531.507] sdcard
[319531.499] SD Card Informations
[319531.500] ====================
[319531.500] ERROR: Reading CID failed with status -256!
[319531.500] ERROR: Reading CSD failed with status -256!
[319531.500]
[319531.500] Reading Root Directory
[319531.500] ======================
[319531.500] SD Card: not connected
[319531.500] Failed to open root directory - error status: 12
[319531.500] done.
I tried two 8 gig sd cards (one Ultra) format FAT 32.
I checked continuity between the solder pads of the sd card before assembly nothing seemed to be causing a short circuit.
Is there a way to trouble shoot SDCard or Connector and the STM32F4 board ?
I couldn’t locate error status codes while searching the forum.
Thanks,
A confused GuitarNut
I’ve never seen this before!
It seems that communication with the SD Card is working, but it doesn’t behave like a common SD Card.
E.g. the CID contains some manufacturer informations, and the CSD some implementation parameters - they can be retrieved.
Would it be possible to try out a different SD Card from another manufacturer?
Can also be a very cheap one.
<= 4 GB cards should be preferred,
Thank you, for the quick response.
Yes, I will try a 4GB card to see if that makes it happy.
I did notice that the same errors occur when there is no SD card in the slot.
I removed the STM32F4 board from the socket and made a continuity test for all pins on the SD card and where they arrive at J16.
I notice some crossed lines in my test, I’m including a drawing showing my results.
<___base_url___>/gallery/image/2694-sd-card-trouble/?do=embed
In my continuity test, pin 9 & 6 of the SD card bridge both RC1 & RC2, while pin 3 joins them at RC1 of J16.
Is this a proper connection?
Thanks
Interesting, I didn’t know this failure more yet.
Yes, if course - the two RC pins should be separated, there shouldn’t be a short between the two pins.
You can doublecheck this by removing the STM32F4DISCOVERY board.
If there is still a short, check the appr. solder joints
Ok,  I tried a 2 gig SD card with no improvement. :no:
Triple checked the solder connections on the board and SD card socket
these seem fine and, I was in correct in my earlier post (I confused the orientation of J16
making me think I had a short between RC1 & RC2 it was actually Vs & Vs).
Do you think I may have damaged the STM32F4 board by powering it up with an incorrectly oriented 74HCT541 chip?
I’m considering purchasing another STM32F4 for comparison.
Thanks
Ok, Good news
I ordered more STM32F4 boards and they all react the same with my Core breakout board.
I didn’t fry the processor board. :slight_smile:
Bad news, Still have a non-functioning SD interface.
I guess I need to remove the current SD Connector and start over.
OK, Finally completed a second Breakout board, this time it worked!  :smile:
Must have messed it up while building it.
Please disregard the graphic earlier in the thread.
I incorrectly labeled the connector.
I wouldn’t want to confuse anyone.
If TK could delete this thread that would be OK with me.
