Does anyone have spare sd card holders for the core or a suggester part substitution? (It is actually for a different pcb but is the same part as used on the stm32f4 core) 3M have stopped manufacturing them and I havent found an alternative that is the same size as
SD-RSMT-2-MQ or
SD-RSMT-2-MQ-WF ( I have found 9/11 pin versions which are shorter with different positions for the mounting tabs). Thanks a lot.
I am trying these as they are similar but a little smaller - will update if they work…
https://uk.rs-online.com/web/p/memory-card-connectors/7636794
EDIT: It works fine - but footprint is a bit smaller so may need gluing as well if the card is going to be removed often.
