Hi there,
I recently bought a used sammichSID equipped with two 8580 SIDs, MIOS 1.9g, running MIDIbox SID V2.044. The problem I’m facing is that only one SID seems to be recognized. So within the ensemble-menu I can only choose SID 1. Also I get only audio-output by one SID.
So I have the following questions:
does the Midibox software perfom any check to determine if the SID may be broken and “disables” it in the frontend-selection?
is there any way to perform a check or debug this issue?
if the SID is broken: would I be able to recognize it in the menue if I would swap both SIDs against each other to check if one is broken? So that the ensemble-screen would say *2** instead of 1***?
software issue?
am I completely missing something, like that the behaviour of the sammichSID differs from the “normal” MIDIbox SID?
Any help or hint would be appreciated ![]()
Thanks,
Chris
