SammichFM failing after 3 minutes (ish)
Heres one which I am having trouble tracking down, SammichFM was working fine, now it seems to shut down, ie produce no sound after about three minutes, display is fine, voltage regulator is +5V, anyone got any ideas?
Thanks
S
What are you feeding it?
What Shuriken is getting at is “what PSU (rating) are you using”? :wink:
Tried 3 differemt PSU’s since posting that, final one is 15VA, so am feeding it 9V, should be plenty of current to spare if it was needed.
What is really throwing me is that the LCD doesn’t dim, the control surface still works, just no output after a few minutes of use.
As I said it was working fine, been away for a month or so, now poorly :-(.
