I sell my used BLM16x16+X.
The Orginal BLM16+16+X has a 8Bit microcontroller, this one has some modifications:
* 32Bit Core Module (Micrcontroller)
* 2x2 Midi IO
* a bootloader switc h, if you bricked somehow the device, with this normally you get it to live…
* and a expansion port on the front (AIN, DIN), (which you maybe never need, except your are a programmer…)
* I soldered yesterday new Faders , so they are brandnew, they are connected to a Serial AIN Board , so they work with 5V! (normally Faders direct connected to a 32bit MCU needs 3.3V, so less resolution) you could mount 12 more faders or pots into it, or via expansion port (DIY…)
* it is 5V USB-Powered , and can be used as USB-Midiinterface , as well there is a sysex protocoll to fast transfair button-led status between a Max-Msp Patch/Ableton live and so on… but for that you have to DIY again
* Theoretical it also can be powered from the SEQV4 , but for that you have to carefulle check the 8-Pin DIN-Socket on the backside off the Device - this holds 2 extra Midi ins 1 Midiout and ±5V — but i dont know if it wired correctly - you may have to check that yourself (DIY!)
I fully cleaned and checked it yesterday (i completely disasaambled and assambled it)
leds are: blue-green-cyan — and all are working
Price: 800
here more detailed Calculation: (without the expansioport, additional midi IO) so you see where the cost is coming from… - i would sell it on sequencer.de - and i think i would find a buyer there - but i cant post there (not enough posts or ±points) -maybe someone can give them a wink…
< base_url >/topic/21123-blm-16x16x-costs-calculation/?do=embed&embedComment=184251&embedDo=findComment#comment-184251
