Roland Juno 106 and Alpha Juno 2 sysex translator
Here is my first custom app using the “new” mios32 environment. :thumbsup:
It only uses a STM 32 board : Juno 106 is connected to Midi in/out 1 and the core32 can be connected to your computer via USB or Midi in/out 2
The purpose is to convert the sysex from the Juno 106 to Control change messages (CC) (and vice versa), in order to edit automations in DAW that don’t support sysex (e.g Ableton Live). Moreover it is really easier to edit CC messages (curves) than sysex ones (list of numbers) !
It does also convert CC messages received on USB and Midi in/out 2 to juno 106 sysex.
  • In Control mode (meaning just moving the faders of the Juno), it sends simple CC.
    • In Patch mode (e.g recalling patch A45 on the Juno), it sends a program change message and all the data of the controls via 18 CC so that you will ever get the patch parameters ; playing the record will transmit those CC and your Juno will return to its original tone :thumbsup:
[*]In Manual mode it only sends all 18 parameters when you press the Manual button on the Juno. Moving faders sends sysex as in Control mode.
Notice that you have to be in Midi Mode III on the Juno. (the only mode that produce sysex)
Control change messages are the following :
Control number of control change message
00 = LFO rate CC 102
01 = LFO delay time CC 103
02 = DCO LFO CC 104
03 = DCO PWM CC 105
04 = DCO Noise CC 106
05 = VCF Freq CC 107
06 = VCF Res etc …
07 = VCF Env
08 = VCF LFO
09 = VCF Kybd
0A = VCA Level
0B = ENV A
0C = ENV D
0D = ENV S …
0E = ENV R CC 116
0F = DCO SUB CC 117
10 = Switches 1 (see below) CC 118
11 = Switches 2 (see below) CC 119
You can change it in app.h by editing CC_Offset. The 102 value has been retained because I needed 18 adjacent numbers.
Enjoy !
Rq : For those curious of some code routines :
 * Juno 106 SysEx Translator v1.0
 * Copyright (C) 2011 Julien Voirin (julien.voirin@free.fr)
 * Licensed for personal non-commercial use only.
 * All other rights reserved.
// Include files
#include <mios32.h>
#include "app.h"
#include "mios32_config.h"
// Translate a DAW CC string from a Juno 106 SysEx string on a destination port
void Translate_CC_SysEx(mios32_midi_package_t midi_package, mios32_midi_port_t port)
	static u8 stream_sysex[7];
	// convert CC:USB0 -> Sysex:UART0 : translate CC to SysEx
	if( midi_package.type == 0xb){
		// define sysex stream
		stream_sysex[0] = 0xf0; // header
		stream_sysex[1] = 0x41; // Roland
		stream_sysex[2] = 0x32; // Juno 106 Control mode
		stream_sysex[3] = midi_package.evnt0 & 0x0f; // midi channel : 0n
		stream_sysex[4] = midi_package.evnt1 - CC_Offset; // Control number
		stream_sysex[5] = midi_package.evnt2; // Control value
		stream_sysex[6] = 0xf7; // EOX
		// send stream to midi out1
		MIOS32_MIDI_SendSysEx(port, stream_sysex, 7);
		//MIOS32_MIDI_SendSysEx(USB0, stream_sysex, 7); // DEBUG :°)
// Translate a Juno SysEx string from a midi port to a Control change string
void Translate_SysEx_CC(mios32_midi_port_t port, mios32_midi_package_t midi_package)
	static u8 editbufferstatus;
	static u8 midi_channel;
	static u8 cc_param;
	static u8 cc_value;
	//	static u8 patch_param[24]; // 24 bytes for a patch
	static u8 bank_patch_number; // for PC
	static u8 patch_value[24]; // Header + midi channel + PgChg + 18 values of controller + EOX
	// convert Sysex:UART0 -> CC:USB0 & CC:UART1
	switch(editbufferstatus){
		unsigned char i; // for the loop
		case 0: // Juno 106 Header
			// Control mode
			if( midi_package.type == 0x4 && midi_package.evnt0 == 0xf0 && midi_package.evnt1 == 0x41 && midi_package.evnt2 == 0x32){
				#if DEBUG
				MIOS32_MIDI_SendCC(USB0, 15, 50, 50);
				#endif
				editbufferstatus = 1;
			// Patch mode
			else if( midi_package.type == 0x4 && midi_package.evnt0 == 0xf0 && midi_package.evnt1 == 0x41 && midi_package.evnt2 == 0x30){
				#if DEBUG
				MIOS32_MIDI_SendCC(USB0, 15, 40, 40);
				#endif
				editbufferstatus = 30;
				//editbufferstatus = 4;
			// Manual mode
			else if( midi_package.type == 0x4 && midi_package.evnt0 == 0xf0 && midi_package.evnt1 == 0x41 && midi_package.evnt2 == 0x31){
				#if DEBUG
				MIOS32_MIDI_SendCC(USB0, 15, 30, 30);
				#endif
				editbufferstatus = 40;
			else
				editbufferstatus = 0;
			break;
		case 1: // 2nd block (3 bytes) : Control
			if( midi_package.type == 0x4) {
				midi_channel = midi_package.evnt0; // CC 1st byte
				cc_param = midi_package.evnt1; // CC 2nd byte (+2 avoid pb with bender)
				cc_value = midi_package.evnt2; // CC 3rd byte
				#if DEBUG
				MIOS32_MIDI_SendCC(USB0, 15, 60, 60); // debug OK
				#endif
				editbufferstatus = 2;
			else
			break;
		case 2: // EOX Control
			if( midi_package.type == 0x5 && midi_package.evnt0 == 0xF7){
				MIOS32_MIDI_SendCC(USB0, midi_channel, cc_param + CC_Offset, cc_value); // USB Port
				MIOS32_MIDI_SendCC(UART1, midi_channel, cc_param + CC_Offset, cc_value); // Midi Out2 Port
				#if DEBUG
				MIOS32_MIDI_SendCC(USB0, 15, 70, 70); // debug OK :)
				#endif
			else
			break;
		case 30: // blocks patch 0n pp dd
			if(midi_package.type == 0x04){
				patch_value[3] = midi_package.evnt0; // midi channel
				patch_value[4] = midi_package.evnt1; // bank patch number
				patch_value[5] = midi_package.evnt2; // ctrl 01 LFO Rate
				// notice that :
				midi_channel = patch_value[3];
				bank_patch_number = patch_value[4];
				// send PC over USB et midi out2
				MIOS32_MIDI_SendProgramChange(USB0, midi_channel, bank_patch_number);
				MIOS32_MIDI_SendProgramChange(UART1, midi_channel, bank_patch_number);
				// next step
				editbufferstatus = 31;
			else
			break;
		case 31: // blocks patch dd dd dd
				patch_value[6] = midi_package.evnt0; // ctrl 02 LFO delay time
				patch_value[7] = midi_package.evnt1; // ctrl 03 DCO LFO
				patch_value[8] = midi_package.evnt2; // ctrl 04 DCO PWM
				// next step
				editbufferstatus = 32;
			else
			break;
		case 32: // blocks patch dd dd dd
				patch_value[9] = midi_package.evnt0; // ctrl 05 DCO noise
				patch_value[10] = midi_package.evnt1; // ctrl 06 VCF Freq
				patch_value[11] = midi_package.evnt2; // ctrl 07 VCF Res
				// next step
				editbufferstatus = 33;
			else
			break;
		case 33: // blocks patch dd dd dd
				patch_value[12] = midi_package.evnt0; // ctrl 08 VCF env
				patch_value[13] = midi_package.evnt1; // ctrl 09 VCF LFO
				patch_value[14] = midi_package.evnt2; // ctrl 10 BCF kbd
				// next step
				editbufferstatus = 34;
			else
			break;
		case 34: // blocks patch dd dd dd
				patch_value[15] = midi_package.evnt0; // ctrl 11 VCA Level
				patch_value[16] = midi_package.evnt1; // ctrl 12 Env A
				patch_value[17] = midi_package.evnt2; // ctrl 13 Env D
				// next step
				editbufferstatus = 35;
			else
			break;
		case 35: // blocks patch dd dd dd
				patch_value[18] = midi_package.evnt0; // ctrl 14 Env S
				patch_value[19] = midi_package.evnt1; // ctrl 15 Env R
				patch_value[20] = midi_package.evnt2; // ctrl 16 DCO Sub
				// next step
				editbufferstatus = 36;
			else
			break;
		case 36: // blocks patch dd dd F7
			if(midi_package.type == 0x07){
				patch_value[21] = midi_package.evnt0; // ctrl 17 Switches 1
				patch_value[22] = midi_package.evnt1; // ctrl 18 Switches 2
				patch_value[23] = midi_package.evnt2; // ctrl EOX
		/* // send PC over USB et midi out2
				// send the patch param via CC
				for(i=5; i < 23; i++){
					MIOS32_MIDI_SendCC(USB0, midi_channel, (i-5)+CC_Offset, patch_value[i]);
					MIOS32_MIDI_SendCC(UART1, midi_channel, (i-5)+CC_Offset, patch_value[i]);
				// return to start
			else
			break;
		case 40: // blocks MANUAL 0n pp dd !NO PROGRAM CHANGE!
				// notice that :
				// DON'T send PC over USB et midi out2
				//MIOS32_MIDI_SendProgramChange(USB0, midi_channel, bank_patch_number);
				//MIOS32_MIDI_SendProgramChange(UART1, midi_channel, bank_patch_number);
				// next step
			else
			break;
		case 4 : // end of Blocks
			break;
// This hook is called after startup to initialize the application
void APP_Init(void)
  // initialize all LEDs
  MIOS32_BOARD_LED_Init(0xffffffff);
// This task is running endless in background
void APP_Background(void)
/* // endless loop
  while( 1 ) {
    // toggle the state of all LEDs (allows to measure the execution speed with a scope)
    MIOS32_BOARD_LED_Set(0xffffffff, ~MIOS32_BOARD_LED_Get());
// This hook is called when a MIDI package has been received
void APP_MIDI_NotifyPackage(mios32_midi_port_t port, mios32_midi_package_t midi_package)
	// toggle Status LED on each incoming MIDI package
	MIOS32_BOARD_LED_Set(1, ~MIOS32_BOARD_LED_Get());
#if TERM_DEBUG	// send received MIDI package to MIOS Terminal
	MIOS32_MIDI_SendDebugMessage("Port:%02X Type:%X Evnt0:%02X Evnt1:%02X Evnt2:%02X\n", port, midi_package.type, midi_package.evnt0, midi_package.evnt1, midi_package.evnt2);
#endif
	// forward USB0->UART0 and UART0->USB0
	switch( port ) {
		case USB0:
			Translate_CC_SysEx(midi_package, UART0);
			MIOS32_MIDI_SendPackage( UART0, midi_package); // forward all messages
			break;
		case UART1:
			// convert CC:UART1 -> Sysex:UART0 : translate CC to SysEx
			break;
		case UART0:
			// translate sysex
			Translate_SysEx_CC( port, midi_package);
			// passthrough midi messages except SysEx
			if (midi_package.type > 0x7 && midi_package.type < 0xf) // all except SysEx
				MIOS32_MIDI_SendPackage(USB0, midi_package);	// USB Port
				MIOS32_MIDI_SendPackage(UART1, midi_package);	// Midi Out2 Port
			break;
[Juno_106_Translator_v1.0.zip](< base_url >/applications/core/interface/file/attachment.php?id=9362)
wow nice. i have no clue to programm codes like this but this is verry nice. i whis i had this for my juno1 and live :slight_smile:
next step but i need to create a control surface first
Brilliance!
Combine the above with a control surface and we get Sysex to the MKS-50/JU-1/2 etc plus CCs to anything reasonably modern :flowers:
This could be full of so much win.
Brilliance!
I quickly started the new application for my Juno 2 : it converts CC to Alpha Juno2 sysex, as i wanted to know if there is scales effect while moving parameters (I got that on my Oberheim Matrix 1000 and it is shit!). There is no scale effect ! :frantics:
so the next step is to build a dedicated control surface.
This application does convert Control Change messages to Juno 2 sysex messages
so that you can control your synth with a DAW that doesn’t support
sysex (e.g Ableton live).
Connect your Juno to Midi in/out sockets 1 of STM32 and USB to your computer.
Midi in/out 2 is the same as USB (e.g to connect to an Akai MPC).
See tables below to edit your Juno parameters (CC84 to CC119).
Have fun !
PS : Am I right we all posess Juno 106 AND Juno2 ?!
 *	Roland Juno 2 SysEx Translator
 *	Copyright (C) 2011 Julien Voirin (julien.voirin@free.fr) *
// Include files
#include <mios32.h>
#include "app.h"
// Translate a DAW CC string from a Juno 2 SysEx string on a destination port
	static u8 stream_sysex[10];
		stream_sysex[2] = 0x36; // Juno 2 in Individual Tone Parameters mode
		stream_sysex[4] = 0x23; // format type
		stream_sysex[5] = 0x20; // unknown
		stream_sysex[6] = 0x01; // unknown
		stream_sysex[7] = midi_package.evnt1 - CC_Offset; // Parameter number
		stream_sysex[8] = midi_package.evnt2; // Parameter value
		stream_sysex[9] = 0xf7; // EOX
		MIOS32_MIDI_SendSysEx(port, stream_sysex, 10);
void APP_Init(void)
  // endless loop
  while( 1 ) {
#endif
	switch( port ) {
		case USB0:
			break;
		case UART1:
			break;
		case UART0:
			// translate sysex from Juno to CC : not yet implemented
			//Translate_SysEx_CC( port, midi_package);
			break;
[Juno_2_SysEx_Translator_v0.1.zip](< base_url >/applications/core/interface/file/attachment.php?id=9370)
I have a Juno-106, a Juno-1 and a Matrix-1000, but no experience with MIOS 32, I have make a board, or two…
Thank you.
here is the final applications
moreover i did a controller on arduino/ethernet/wifi and iPad/touchOSC for Roland Juno2
ARDUINO CODE for Juno2 sysex translator :
// OSCClass iOSC(iPhone App) test sketch
// OSCClass version 1.0.1 (Arduino ver0014)
// Copyright (c) recotana(http://recotana.com). All right reserved.
TouchOSC is OSCsend Application for iPad
 OSC setting example :
             OSCMessage type value on off
 button1 /Juno2/button_name float 1 0 :info-AlternateMode "ON" = toggle sw
 slider1 /Juno2/button_name float 1 0
 Arduino setting IP address 192.168.1.10 , incoming port : 8000 (server)
 Arduino setting IP address 192.168.1.10 , outgoing port : 8008
 iPad setting IP address 192.168.1.4 , incoming port : 8008 (client)
 iPad setting IP address 192.168.1.4 , outgoing port : 8000
 Parameters on the Juno2 :
 I. First scroll through the MIDI menu and turn Exclusive Messages ON.
 II. These are the components of the system exclusive message:
 F0 [Exclusive]
 41 [Roland ID#]
 36 [Individual Tone Parameters]
 0N [N=MIDI channel (N=0-F, Chan 1=00 Chan 16=0F)]
 23 [Format type]
 20 [unknown]
 01 [unknown]
 XX [Parameter number (0-23)] see table below
 YY [Value (0-127)] Can be left at 00
 F7 [End of Exclusive]
 III. Here is an example:
 A SysEx message for editing the VCF Resonance Parameter on MIDI channel 1:
 F0 41 36 00 23 20 01 11 00 F7
 "11" Is the SysEx code for the VCF Resonance edit parameter.
 "00" Is the SysEx code for the variable start value of the current edit parameter.
 Parameter Numbers (XX) For The Alpha Juno Synths: 37 parameters
 (Parentheses indicated range of variable values 'YY' possible for the parameter.)
 CODE (XX)	EDIT PARAMETER COMPLETE SYSEX CODE CC#
 00	DCO Env. Mode (0=Normal, 1=Inverted, 2=Normal-Dynamic, 3=Inv.-Dynamic) F0 41 36 00 23 20 01 00 00 F7	84
 01	VCF Env. Mode (0=Normal, 1=Inverted, 2=Normal-Dynamic, 3=Dynamic) F0 41 36 00 23 20 01 01 00 F7	85
 02	VCA Env. Mode (0=Normal, 1=Gate, 2=Normal-Dynamic, 3=Gate-Dynamic) F0 41 36 00 23 20 01 02 00 F7	86
 03	DCO Wave Pulse (0..3) F0 41 36 00 23 20 01 03 00 F7	87
 04	DCO Wave Saw (0..5) F0 41 36 00 23 20 01 04 00 F7	88
 05	DCO Wave Sub (0..5) F0 41 36 00 23 20 01 05 00 F7	89
 06	DCO Range (0=4', 1=8', 2=16', 3=32') F0 41 36 00 23 20 01 06 00 F7	90
 07	DCO Sub Level (0..3) F0 41 36 00 23 20 01 07 00 F7	91
 08	DCO Noise (0..3) F0 41 36 00 23 20 01 08 00 F7	92
 09	HPF Cutoff (0..3) F0 41 36 00 23 20 01 09 00 F7	93
 0A	Chorus Switch (0=Off, 1=On) F0 41 36 00 23 20 01 0A 00 F7	94
 0B	DCO LFO Mod. (0..7F) F0 41 36 00 23 20 01 0B 00 F7	95
 0C	DCO ENV Mod. (0..7F) F0 41 36 00 23 20 01 0C 00 F7	96
 0D	DCO After Mod. (0..7F) F0 41 36 00 23 20 01 0D 00 F7	97
 0E	DCO PWM Depth (0..7F) F0 41 36 00 23 20 01 0E 00 F7	98
 0F	DCO PWM Rate (0..7F) 0 = Pulse Width Manual 1..7F = PW LFO Rate F0 41 36 00 23 20 01 0F 00 F7	99
 10	VCF Cutoff (0..7F) F0 41 36 00 23 20 01 10 00 F7	100
 11	VCF Resonance (0..7F) F0 41 36 00 23 20 01 11 00 F7	101
 12	VCF LFO Mod. (0..7F) F0 41 36 00 23 20 01 12 00 F7	102
 13	VCF ENV Mod. (0..7F) F0 41 36 00 23 20 01 13 00 F7	103
 14	VCF Key Follow (0..7F) F0 41 36 00 23 20 01 14 00 F7	104
 15	VCF Aftertouch (0..7F) F0 41 36 00 23 20 01 15 00 F7	105
 16	VCA Level (0..7F) F0 41 36 00 23 20 01 16 00 F7	106
 17	VCA Aftertouch (0..7F) F0 41 36 00 23 20 01 17 00 F7	107
 18	LFO Rate (0..7F) F0 41 36 00 23 20 01 18 00 F7	108
 19	LFO Delay (0..7F) F0 41 36 00 23 20 01 19 00 F7	109
 1A	ENV T1 (0..7F) Attack Time F0 41 36 00 23 20 01 1A 00 F7	110
 1B	ENV L1 (0..7F) Attack Level F0 41 36 00 23 20 01 1B 00 F7	111
 1C	ENV T2 (0..7F) Break Time F0 41 36 00 23 20 01 1C 00 F7	112
 1D	ENV L2 (0..7F) Break Level F0 41 36 00 23 20 01 1D 00 F7	113
 1E	ENV T3 (0..7F) Decay Time F0 41 36 00 23 20 01 1E 00 F7	114
 1F	ENV L3 (0..7F) Sustain Level F0 41 36 00 23 20 01 1F 00 F7	115
 20	ENV T4 (0..7F) Release Time F0 41 36 00 23 20 01 20 00 F7	116
 21	ENV Key Follow (0..78) F0 41 36 00 23 20 01 21 00 F7	117
 22	Chorus Rate (0..7F) F0 41 36 00 23 20 01 22 00 F7	118
 23	Bender Range (0..C) F0 41 36 00 23 20 01 23 00 F7	119
#include "Ethernet.h"
#include <OSCClass_018.h>
#include "MIDI.h"
#define _POT_DEBUG_ 0 // set to 1 to debug with pot
#define LED_PWM 6 // red led of midi shield
#define POT_PIN 0
#define SW_PIN 3
#define note_offset 36
#define midi_channel 1
OSCMessage recMes;
OSCMessage sendMes;
OSCClass osc(&recMes);
// server cfg (arduino)
byte serverMac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte serverIp[] = { // arduino IP
  192, 168, 0, 13 };
int serverPort = 8000; // outgoing from iPad, incoming to arduino
// byte gateway[] = { 192, 168, 1, 2 };
// byte subnet[] = { 255, 255, 255, 0 };
// client cfg
byte destIp[] = {
  192, 168, 0, 19}; // iPad IP
int destPort = 8008; // outgoing from arduino, incoming to iPad
char *Juno2_OSC_name[3] = {
  "/jun",
  "/note",
  "/ctrl"
char *Juno2_OSC_param_name[37] = { // 36 parameters
  "/DCO_Env_Mode", // $00
  "/VCF_Env_Mode", // $01
  "/VCA_Env_Mode", // $02
  "/DCO_Wave_Pulse", // $03
  "/DCO_Wave_Saw", // $04
  "/DCO_Wave_Sub", // $05
  "/DCO_Range", // $06
  "/DCO_Sub_Level", // $07
  "/DCO_Noise_Level",// $08
  "/HPF_CutOff", // $09
  "/Chorus_Switch", // $0a
  "/DCO_Lfo_Mod", // $0b
  "/DCO_Env_Mod", // $0c
  "/DCO_After_Mod", // $0d
  "/DCO_Pwm_Depth", // $0e
  "/DCO_Pwm_Rate", // $0f
  "/VCF_CutOff", // $10 d16
  "/VCF_Resonance", // $11
  "/VCF_Lfo_Mod", // $12
  "/VCF_Env_Mod", // $13
  "/VCF_Key_Follow", // $14
  "/VCF_Aftertouch", // $15
  "/VCA_Level", // $16
  "/VCA_Aftertouch", // $17
  "/LFO_Rate", // $18
  "/LFO_Delay", // $19
  "/ENV_T1", // $1a
  "/ENV_L1", // $1b
  "/ENV_T2", // $1c
  "/ENV_L2", // $1d
  "/ENV_T3", // $1e
  "/ENV_L3", // $1f
  "/ENV_T4", // $20
  "/ENV_Key_Follow", // $21
  "/Chorus_Rate", // $22
  "/Bender_Range", // $23
// Arrays of patch parameters values
byte Juno2_SysEx_Patch_APR[54]; // whole patch
byte Juno2_SysEx_Patch_IPR[10]; // single parameter
char *midi_note[12] = {
  "/key_0",
  "/key_1",
  "/key_2",
  "/key_3",
  "/key_4",
  "/key_5",
  "/key_6",
  "/key_7",
  "/key_8",
  "/key_9",
  "/key_10",
  "/key_11",/*
  "/key_12",
  "/key_13",
  "/key_14",
  "/key_15",
  "/key_16",
  "/key_17",
  "/key_18",
  "/key_19",
  "/key_20",
  "/key_21",
  "/key_22",
  "/key_23",
  "/key_24",
  "/key_25",
  "/key_26",
  "/key_27",
  "/key_28",
  "/key_29",
  "/key_30",
  "/key_31",
  "/key_32",
  "/key_33",
  "/key_34",
  "/key_35",
  "/key_36",
  "/key_37",
  "/key_38",
  "/key_39",
  "/key_40",
  "/key_41",
  "/key_42",
  "/key_43",
  "/key_44",
  "/key_45",
  "/key_46",
  "/key_47",
  "/key_48",
  "/key_49",
// pot, led & switch flags
boolean ledFlag;
boolean swFlag;
long oldPotValue;
// Init
void setup() {
  // set midi baudsrate
// Serial.begin(31250); // old method without midi.h --> don't use
  // Serial.print("reset");
  // Initiate MIDI communications, listen to all channels
  MIDI.begin(MIDI_CHANNEL_OMNI);
  // Connect the HandleSysex function to the library, so it is called upon reception of a sysex.
  MIDI.setHandleSystemExclusive(HandleSystemExclusive); // Put only the name of the function
  Ethernet.begin(serverMac ,serverIp);
  // Ethernet.begin(serverMac ,serverIp ,gateway ,subnet);
  // setting osc recieve server
  osc.begin(serverPort);
   // init osc send < --- pose pb si logMessage est compilé
   sendMes.setIp( destIp );
   sendMes.setPort( destPort );
  // LED OFF
  pinMode(LED_PWM, OUTPUT);
  digitalWrite(LED_PWM, HIGH);
  // switch and pot
  pinMode(SW_PIN, INPUT);
  ledFlag = false;
  swFlag = false;
  analogReference(DEFAULT);
  oldPotValue = (long)analogRead(POT_PIN);
  // osc message buffer clear
  osc.flush();
// Mainloop
void loop()
  // osc arrive check
  if ( osc.available() ){
    OSC_SYSEX();
    OSC_NOTE(recMes);
  else{
  // midi arrive check
    if (MIDI.read()) { // Is there a MIDI message incoming ?
    switch(MIDI.getType()) { // Get the type of the message we caught
      case SystemExclusive: // If it is a sysex
	SYSEX_OSC( MIDI.getData1(), MIDI.getSysExArray() );	// call SYSEX_OSC function
        break;
      // See the online reference for other message types
      default:
        break;
#ifdef _POT_DEBUG_
  // pot active send VCF CutOff
  POT_OSC();
#endif
void HandleSystemExclusive(byte *array, byte size)
// Convert OSC to Sysex
void OSC_SYSEX(void)
    // toplevel address matching
    if( !strcmp( recMes.getAddress(0) , Juno2_OSC_name[0] ) ){ // "/jun"
      // second level address matching
      if( !strcmp( recMes.getAddress(1) , Juno2_OSC_param_name[0] ) ){
        MIDI_SEND_IPR(0, recMes.getArgFloat(0));
      else if(!strcmp( recMes.getAddress(1) , Juno2_OSC_param_name[1])){
        MIDI_SEND_IPR(1, recMes.getArgFloat(0));
      else if(!strcmp( recMes.getAddress(1) , Juno2_OSC_param_name[2])){
        MIDI_SEND_IPR(2, recMes.getArgFloat(0));
      else if(!strcmp( recMes.getAddress(1) , Juno2_OSC_param_name[3])){
        MIDI_SEND_IPR(3, recMes.getArgFloat(0));
      else if(!strcmp( recMes.getAddress(1) , Juno2_OSC_param_name[4])){
        MIDI_SEND_IPR(4, recMes.getArgFloat(0));
      else if(!strcmp( recMes.getAddress(1) , Juno2_OSC_param_name[5])){
        MIDI_SEND_IPR(5, recMes.getArgFloat(0));
      else if(!strcmp( recMes.getAddress(1) , Juno2_OSC_param_name[6])){
        MIDI_SEND_IPR(6, recMes.getArgFloat(0));
      else if(!strcmp( recMes.getAddress(1) , Juno2_OSC_param_name[7])){
        MIDI_SEND_IPR(7, recMes.getArgFloat(0));
      else if(!strcmp( recMes.getAddress(1) , Juno2_OSC_param_name[8])){
        MIDI_SEND_IPR(8, recMes.getArgFloat(0));
      else if(!strcmp( recMes.getAddress(1) , Juno2_OSC_param_name[9])){
        MIDI_SEND_IPR(9, recMes.getArgFloat(0));
      else if(!strcmp( recMes.getAddress(1) , Juno2_OSC_param_name[10])){
        MIDI_SEND_IPR(10, recMes.getArgFloat(0));
      else if(!strcmp( recMes.getAddress(1) , Juno2_OSC_param_name[11])){
        MIDI_SEND_IPR(11, recMes.getArgFloat(0));
      else if(!strcmp( recMes.getAddress(1) , Juno2_OSC_param_name[12])){
        MIDI_SEND_IPR(12, recMes.getArgFloat(0));
      else if(!strcmp( recMes.getAddress(1) , Juno2_OSC_param_name[13])){
        MIDI_SEND_IPR(13, recMes.getArgFloat(0));
      else if(!strcmp( recMes.getAddress(1) , Juno2_OSC_param_name[14])){
        MIDI_SEND_IPR(14, recMes.getArgFloat(0));
      else if(!strcmp( recMes.getAddress(1) , Juno2_OSC_param_name[15])){
        MIDI_SEND_IPR(15, recMes.getArgFloat(0));
      else if(!strcmp( recMes.getAddress(1) , Juno2_OSC_param_name[16])){
        MIDI_SEND_IPR(16, recMes.getArgFloat(0));
      else if(!strcmp( recMes.getAddress(1) , Juno2_OSC_param_name[17])){
        MIDI_SEND_IPR(17, recMes.getArgFloat(0));
      else if(!strcmp( recMes.getAddress(1) , Juno2_OSC_param_name[18])){
        MIDI_SEND_IPR(18, recMes.getArgFloat(0));
      else if(!strcmp( recMes.getAddress(1) , Juno2_OSC_param_name[19])){
        MIDI_SEND_IPR(19, recMes.getArgFloat(0));
      else if(!strcmp( recMes.getAddress(1) , Juno2_OSC_param_name[20])){
        MIDI_SEND_IPR(20, recMes.getArgFloat(0));
      else if(!strcmp( recMes.getAddress(1) , Juno2_OSC_param_name[21])){
        MIDI_SEND_IPR(21, recMes.getArgFloat(0));
      else if(!strcmp( recMes.getAddress(1) , Juno2_OSC_param_name[22])){
        MIDI_SEND_IPR(22, recMes.getArgFloat(0));
      else if(!strcmp( recMes.getAddress(1) , Juno2_OSC_param_name[23])){
        MIDI_SEND_IPR(23, recMes.getArgFloat(0));
      else if(!strcmp( recMes.getAddress(1) , Juno2_OSC_param_name[24])){
        MIDI_SEND_IPR(24, recMes.getArgFloat(0));
      else if(!strcmp( recMes.getAddress(1) , Juno2_OSC_param_name[25])){
        MIDI_SEND_IPR(25, recMes.getArgFloat(0));
      else if(!strcmp( recMes.getAddress(1) , Juno2_OSC_param_name[26])){
        MIDI_SEND_IPR(26, recMes.getArgFloat(0));
      else if(!strcmp( recMes.getAddress(1) , Juno2_OSC_param_name[27])){
        MIDI_SEND_IPR(27, recMes.getArgFloat(0));
      else if(!strcmp( recMes.getAddress(1) , Juno2_OSC_param_name[28])){
        MIDI_SEND_IPR(28, recMes.getArgFloat(0));
      else if(!strcmp( recMes.getAddress(1) , Juno2_OSC_param_name[29])){
        MIDI_SEND_IPR(29, recMes.getArgFloat(0));
      else if(!strcmp( recMes.getAddress(1) , Juno2_OSC_param_name[30])){
        MIDI_SEND_IPR(30, recMes.getArgFloat(0));
      else if(!strcmp( recMes.getAddress(1) , Juno2_OSC_param_name[31])){
        MIDI_SEND_IPR(31, recMes.getArgFloat(0));
      else if(!strcmp( recMes.getAddress(1) , Juno2_OSC_param_name[32])){
        MIDI_SEND_IPR(32, recMes.getArgFloat(0));
      else if(!strcmp( recMes.getAddress(1) , Juno2_OSC_param_name[33])){
        MIDI_SEND_IPR(33, recMes.getArgFloat(0));
      else if(!strcmp( recMes.getAddress(1) , Juno2_OSC_param_name[34])){
        MIDI_SEND_IPR(34, recMes.getArgFloat(0));
      else if(!strcmp( recMes.getAddress(1) , Juno2_OSC_param_name[35])){
        MIDI_SEND_IPR(35, recMes.getArgFloat(0));
      else if(!strcmp( recMes.getAddress(1) , Juno2_OSC_param_name[36])){
        MIDI_SEND_IPR(36, recMes.getArgFloat(0));
      else if(!strcmp( recMes.getAddress(1) , Juno2_OSC_param_name[37])){
        MIDI_SEND_IPR(37, recMes.getArgFloat(0));
      else{
        // rien
    else if( !strcmp( recMes.getAddress(0) , Juno2_OSC_name[1] ) ){
        // Note On OSC message
    else{
      // to complete
// Send Juno2 SysEx string
void MIDI_SEND_IPR( char osc_param_name, double osc_param_value)
  //byte sysex_param_value = (byte)osc_param_value; // transform that shit !
  // visual feedback LED
  analogWrite(LED_PWM, floor(255 - osc_param_value));
 // set IPR sysex bytes : F0 41 36 00 23 20 01 name value F7
 Juno2_SysEx_Patch_IPR[0] = 0xf0;
 Juno2_SysEx_Patch_IPR[1] = 0x41;
 Juno2_SysEx_Patch_IPR[2] = 0x36;
 Juno2_SysEx_Patch_IPR[3] = 0x00;
 Juno2_SysEx_Patch_IPR[4] = 0x23;
 Juno2_SysEx_Patch_IPR[5] = 0x20;
 Juno2_SysEx_Patch_IPR[6] = 0x01;
 Juno2_SysEx_Patch_IPR[7] = (byte)osc_param_name;
 Juno2_SysEx_Patch_IPR[8] = (byte)osc_param_value; // sysex_param_value
 Juno2_SysEx_Patch_IPR[9] = 0xf7;
 // send 10 bytes sysex array, including F0 & F7 (true)
 MIDI.sendSysEx( 10, Juno2_SysEx_Patch_IPR, true );
 // ça marche :)
// convert SYSEX in OSC
void SYSEX_OSC( byte size, byte *sysex_array )
  // if it is a 54 bytes sysex string = APR
  if (size == 54){
    for (char i=0; i<55; i++)
    Juno2_SysEx_Patch_APR[i] = sysex_array[i]; // extract param values from sysex
    // convert APR to 38xIPR message
    for (char p=0; p<39; p++){
      sendMes.setTopAddress(Juno2_OSC_name[0]); // "/jun"
      sendMes.setSubAddress( (char*)Juno2_OSC_param_name[p] ); // e.g "/VCF_CutOff"
      float f = sysex_array[7 + p] + 0.000; // transform to float shit
      sendMes.setArgs( "f", &(f) );
      osc.sendOsc( &sendMes );
      delay(10); // small delay to see faders moving ;)
  // if it is a 38 bytes sysex string = not implemented
  else if (size == 38){
    // do stuff
  // if it is a 10 bytes sysex string = IPR
  else if (size == 10){
    // transform array
    for (char j=0; j<11; j++)
    Juno2_SysEx_Patch_IPR[j] = sysex_array[j];
    //OSC send IPR
    sendMes.setSubAddress( (char*)Juno2_OSC_param_name[Juno2_SysEx_Patch_IPR[7]] ); // e.g "//VCF_CutOff"
    float f = Juno2_SysEx_Patch_IPR[8] + 0.000; // convert in float
    sendMes.setArgs( "f", &(f) ); // e.g "120."
#ifdef _POT_DEBUG_
// Convert POT to OSC VCF_CutOff message
void POT_OSC(void)
  int pot=analogRead(POT_PIN); //adc data = 10bit data
  long value = (long)(pot >> 3); // 1024 -> 127
  if( oldPotValue != value ){
    sendMes.setSubAddress(Juno2_OSC_param_name[16] ); // "/jun/VCF_CutOff"
    sendMes.setArgs( "i", &value );
    // Serial.print("pot:");
    // Serial.println(value);
   oldPotValue = value;
#endif
// Convert OSC Note message
void OSC_NOTE(OSCMessage recMes)
    if( !strcmp( recMes.getAddress(0) , Juno2_OSC_name[1] ) ){ // "/note"
      for(char k=0; k<12; k++){
        if( !strcmp( recMes.getAddress(1) , midi_note[k] ) ){
           MIDI.sendNoteOn((byte)( k + note_offset), (byte)recMes.getArgFloat(0), midi_channel);
          //MIDI.sendNoteOn((byte)(i + 60), (byte)recMes.getArgFloat(0), 1);
//// Send Note from OSC
//void MIDI_SEND_NOTE(long note, double velocity)
// MIDI.sendNoteOn((byte)note, (byte)velocity, 1);
[Juno_106_Translator_v1.1.zip](< base_url >/applications/core/interface/file/attachment.php?id=9829)
Hey Julien,
Big thanks for that stuff.. i was searching for it since a while.. now i just have to find how to compile the code… any idea ? :wink:
Best Regards,
Dave
yes that helps ,thx
