Hi.
I know that it isn’t ‘technically’ MIOS, but I have been building a MIDI<->RS-232 translator (for Sony Minidisc control) and I am using an IIC MIDI and an LTC module (I suppose you could call it “IIC RS-232”).
The IIC Midi code does quite a bit of processing to check that it is a valid Midi stream which I don’t want it to do. I have done a quick-and-dirty hack to prot.asm which forces all bytes to be sent as single byte MIDI (F8-FF) whereby I commented out andlx 0xf8 and xorlw 0xf8 in PROT_Tick_Rx_NewStatus!
I know that this isn’t perfect as it means that 2 bytes are sent over the I2C for each 1 byte of RS-232 but as I am working at 9600baud I wasn’t concerned about this.
Is there a more elegant way of achieving this? As it isn’t exactly easy to debug the IIC I didn’t want to change too much and I last used assembler on 6502’s in the late 80’s!
Phil
