read through this: http://ucapps.de/mbhp_lcd.html
I did read it. But I thought the MISO Studio replaced the need for the LCD display?
Jay
Jay
Plenty of people have managed to bring up a Midibox without the LCD display. However, I still think it is handy to have, especially on your first Midibox. MIOS Studio requires that you have a computer and a MIDI connection to the computer. The LCD display gives you an independent way of seeing what the Core is doing. For a $1 more I’d go with the 2x40.
Thanks Jim
All
I placed my order with TIM. I also ordered the 40 x 2 LCD display. Does it connect directly to the Core8 or do I need additional things?
Thanks, Jay
I hope you looked at the WIKI to be sure the LCD you picked is compatible with the Core. I assumed you had so I didn’t say anything. There is a link on that page to my guide for connecting an LCD.
I have not ordered the LCD yet so will look at the Wiki. I did order from Tim all the kits, connectors, and ribbon cables.
The 2 x 16 has a HD44780 controller. And a spec sheet is available. The other one had no info available. This one is $7.50 so can’t lose much in that deal. Will order it with some other stuff I need for my model railroad signal system.
Will wait to hear back from you before placing the order with AllElectronics.com
Thanks for all your help.
Jay
I have attached the spec sheet if interested.
[LCD-16216.pdf](< base_url >/applications/core/interface/file/attachment.php?id=9164)
If in the future I want to add Combination Pistons/Buttons would that just involve either left over space on my 7th DIN or the use of a 8th DIN?
If I wanted to add SAMS where would I get them and what would I expect to pay?
I assume that SAMS would require DOUT boards and would they attach to the Output pins on the Core8?
As I recall the CORE8 can support 128 inputs as well as 128 output (via DOUT)?
Thanks
