I learned of Neutrik audio jacks on the SID-NUXX site. The jacks have 6 pins whereas the SID PCB only has + and a - jumpers. It is a stereo jack but not sure why there are 6 pins instead of 4.
Anyway, for now I just want to go mono and maybe deal with stereo later. So in absence of information, I thought I would use logic (uh - make that “noob logic”).
What I was thinking of doing is running a regular 1/4 inch mono cable out of a Roland into the jack. Play Twinkle, Twinkle Little Star via Ye Olde Sequencer or something. Then I would test the pins with a multimeter to see which is testing positive and negative for the Twinkle signal. After that, when wiring the Neutrik to the board, I would wire the *positive* pin to the negative jumper on the PCB and the negative pin to the positive jumper on the PCB. The reason being is that when testing with the Roland, I would be sending audio *into* the jack, whereas when the jack is connected to the PCB, I would send the SID’s audio out of the jack (requiring a reversal of roles).
Does this sound right to anyone - or am I cruising for an oozing (of SID components)?
I looked at the datasheet (below). However, there is no positive and negative listing of pins on here so it was not informative. I also searched the forum for Neutrik to no avail…
http://www.neutrik.com/content/products/detail.aspx?id=210_980737404&catId=CatMSDE_audio/
Thanks!
