PSU noob...
Hello,
I am building my first MBsynth and I want to built my own PSU… I have saw on pictures that TK mades his own PSU for his two units 19" rack OPL3 synth…
Where can I find the components list, and a PCB for that 5 v and 12 +/- v PSU?
Thanks
Faton
It’s all in the WIKI :smiley:
http://www.midibox.org/dokuwiki/northernlightx?s=psu
http://www.midibox.org/dokuwiki/bipolar_12v_psu?s=psu
Thanks ;D
I just finished my PSU based on northernlightx shematic. I have +5V, +9V, +12V, but -17V at the 7912 output…
Do you think it can be dangerous to connect the OPL3 on +12/-17 V?
Maybe the regulator is dead?
Sounds like you measured from the +5V line, you should measure from GND to -12V. Could you double check?
I’ve had the same problem (-17V at the 7912) with various 7912s from the same manufacturer. Solved the problem by getting different 7912s.
Heh, what’s a 7912 when a 7912 is not a 7912? a 7917, of course!
Who’s the dodgy brand we should avoid, nILS?
Can’t check right now, as they are back home. But, they’re the ones Conrad sells in their stores :slight_smile: I’ll check when I get back home next weekend. Um, if I don’t post an update here within the next 10 days, could someone remind me, please?
Thanks, I will try another brand…  :-\
I’ve had issues with 7912s as well.  IIRC the problems I was experiencing were with ST’s 79xx regulators.  From a bit of Googling, I believe it had something due to them locking up (?) when there was no current draw on the output.  Supposedly it could be fixed by  adding a resistor to ensure a constant current draw during power-on, but that didn’t seem to resolve the issue that I was having, either.  Recently I picked up some 7912s from two other sources… and both of those sent me ST units as well.  ARGH.
I think I’m going to be reduced to using a MAX660 or an SI7661, etc. as a voltage inverter for my bipolar supplies.
I have tried again with another 7912 from ST electronic, and now it works fine  ;D
I have my +5, +9, +12, -12 PSU very clean and stable…
Thanks to Northernlight!!
