Hi Guys,
Just thought I’d run this project idea past you. It’s not specifically a question, just a set of “what if” type thoughts, that I’d be grateful for your opinions and suggestions on.
First of all about me… I’m not a total electronics noob, but I’m no expert in the subject either. I’m a self taught musician with engineering and some software skills, and I’m currently pretty broke, which is what made me seek out solutions and what led me to find the Midibox Project in the first place.
OK… That aside, the idea I have is to construct a hardware synth, with a software underbelly. I know it’s been done by other people and I am reading as much as I can from the forum and the documentation and I think I should be able to do this with the Midibox core and all the help available on here. So here’s the plan:
I fell in love with the Sequential Circuits Prophet 5, back in the 80’s… But I’ve never been able to afford one. Even more so now that they cost WAY too much as collectors items. Even if I did afford one, vintage synths are unreliable and unstable at the best of times.
SO! I figure, build an affordable and reliable replica!! ![]()
Here’s the components I’m thinking of using… Midibox 64E… Plus enough input boards to give me all the pots and switches (in this case rotary controls and switches) of the original synth… plus a few extras… LCD display instead of the LED display on the original synth.
Inside the replica Prophet 5 case, will be buried a Mini ITX Motherboard to run the software synth (not entirely decided which of the available software emulations to run yet), with a good sound card plugged into it, to give good quality audio output… Plus all the Midibox parts to run the front panel.
I figure, use rotary controls rather than pots, so that whatever patch I set the software synth into, the front panel will immediately mimic the correct positions of the controls.
Now… this is the point where I run into snags… Obviously the keyboard of this synth has to be functional (it’s not just a midi expander module) So I figure that either I have to use a second Midibox Core to handle the input from the switches on all the keys (the original synth was not velocity sensitive so switch on or off inputs would work fine as a key interface), or I have to bury the guts of a cheap MIDI synth inside to provide the key input in midi form that can then be fed to the Midibox hardware and merged with the front panel controls before being sent to the Mini ITX PC Board for the emulation to deal with… Any thoughts you guys have on this would be useful.
Best Regards,
Julian (Fozzy The Bear)
